Hi There, I have been trying to get an answer to the same question without success. I had two visits, one heater core flush, and one complete tear down at the dealer to repair this issue. First the heater flush due to the recall, then the plugged heater core a second time. The original problem was always low heat driver's side. I brought it back to the dealer and they want to charge 1200 to fix. the diagnosis was 250$ which would come off the 1200 if I went ahead with the repair. The dealer did some basic diagnostics to determine that the plenum needs to be completely replaced as it comes as a kit. WTF was my response, no heat for a car in Canada, great job Ford.
I tried to pull out the blend door actuator and succeeded, but honestly could not tell if it operated properly at all the control points as i varied cabin heat on the console with the unit in my hand and wired. it seemed to be a little jumpy if i could say that. when I manually operated the blend door, i would get heat at one extreme. so i guess the quickest troubleshooting and least costly is to order the blend door actuator and see if the stepper motor is messed up. if it is not that, then i will sell the car as it is of little use and losing value by the week and almost only worth have as much as the repair will cost.
would appreciate as well if someone could respond with the troubleshooting tips or video on blend door replacement for ford edge as the heater core is not plugged.
Thanks!
