Hi
I seem to be having AC issues, unless this is normal, but I dont feel like it is. My AC temperature either does not change much, or goes from on extreeme to the next with just one to two degree temp. change. I can set the temperature at 83 degrees and it blows rather cold air, but bump it up just to degrees and you are at HI or basically heat and its burning up. Then if go back down two degrees to where it was before at 83, its still just as hot as it is at HI. Is that normal?? I took it in to get looked at and they told me they ran tests and there is nothing wrong with anything to do with my AC system. But I just dont fel like this can be normal, I feel like I am crazy after I took it in because they told me it is perfectly fine. But how is being able to set the the temperature at 70 degrees or 80 degrees and the same temperature of air blows out normal? PLEASE HELP!
