No shifting issues, no error codes, battery drain is significant if headlights are being used even when being driven. Charging voltage drops to 11.4 volts and lower at idel speeds. With no load (lights off just maintaining normal operations on radio, nav or other option being used) voltage starts at 13.5 after full battery charge but then drops below 12 volts within 10 minutes even with car running at idel. As a check with battery disconnected it maintains its charge so the drain is from the car. I am very frustrated that there appears to be no logical way to isolate the source of the power drain. I have put a volt meter on the battery while it is running setting in the dealers shop and you can watch the voltage drop rather rapidly, a few tenths of a volt every few seconds.
