bsk6294
Everything posted by bsk6294
  1. Yes. And I think personally, my issues began shortly after I replaced the battery without resetting the battery management system. YMMV.
  2. Have you recently changed the battery? I still have the rough shifting, but I have not had the stall since I reset the battery via Forscan. I don't think the system does a proper reset of voltage, etc when you replace the battery, even if you do the "unplugged" for 24 hours. Resetting the battery monitor system seems to have helped.
  3. I have had this issue intermittently for years now, but am unable to replicate it. The codes are often different but usually about losing comms. My thought is that under heavy acceleration, between the transmission shift and AWD kicking in, plus the traction control, throttle adjustments, etc, the likely underpowered computer and "networks" get overwhelmed, and it forces everything into limp mode. May try changing out the transmission and/or PTU fluids, but it's been behaved the last few months.
  4. Excellent. Very helpful. Thanks a ton! I guess I know what I'll be doing this weekend
  5. Paul, I'm currently trying to install TWakefield's 3d-printed parts. How were you able to get the seat cover removed? I have a 2017 Edge Sport and there don't seem to be any zippers or closures. I got as far as the j-channels, but am having an issue getting the seat cover out of the way enough to install the fix. Thanks, Brian
  6. Did you ever have any luck removing the seat covers? I'm attempting this same fix now and running into the same problem. Thanks!
