RobynL_328
Everything posted by RobynL_328
  1. I have no buttons on or around the instrument cluster. And in the system check report, there are no other options to select after it reports the distance to empty. So neither instructions will work. Although I appreciate the copy of the owners manual, I will review it to see if there are alternate instructions that will help. In the meantime, if anyone has any other ideas, I would appreciate it.
  2. Hi, So I let my boyfriend borrow my Edge for a couple of days and when I got it back, the temperature display was in Celsius and my dash display by the steering wheel had everything in kilometers. He said he has no idea how he did this! Figures. Does anyone know how I can switch it back? I can't find instructions specific to the 2008 edge limited. Thank you in advance! Robyn
  3. Hi, I have a dumb question because I don't know anything about cars. My 2008 Edge Limited started overheating today. I drove to work this morning and everything seemed fine. Went to truck on a break, started it up & turned on the AC as usual, and I realized it wasn't working, it wasn't getting cold. Drove to the store that's next door to my office and that's when I see the temp gauge read all the way hot. I switched to max heat but it didn't help much at that point. Checked the coolant reservoir to see if it was empty (had a massive leak in the system recently, causing this tank to empty out & overheating). The reservoir had coolant but I noticed a very small hole at the top. I don't ever recall having seen it before. It definitely goes all the way through. Could this be causing the overheating?
  4. Hi everyone. My Edge just started doing this thing where when I go to start the vehicle, it starts to crank as normal, however, at the point where I would let go (because the truck has started up), it continues to crank on its own. I haven't let it do this for very long, perhaps 5 or 6 seconds at most, before I switch the key to off. I wait a couple of seconds, then attempt to start again, at which point it starts up immediately as normal. I feel like I should mention also that the only thing I've noticed that is a little "off" is that since this cranking issue began, when I start the truck normally, it sounds/feels like it's just a hair sluggish, kind of like how it feels when the battery is going bad or something. Incidentally, my battery is most certainly not going bad, it's no more than a year old, if that. Can someone tell me what the possible causes are of this excessive cranking issue?? Thank you!
  5. I've noticed the last week or so that when I'm parked and idling, my AC will sometimes stop working and the air no longer blows cold. I can hear the compressor kicking on but it doesn't cool the air. I'll have to put it in drive and start driving around before it gets cold again. Is my AC compressor going bad? I'm in a 2008 Ford Edge Limited w 157k miles
  6. I've noticed the last week or so that when I'm parked and idling, my AC will sometimes stop working and the air no longer blows cold. I can hear the compressor kicking on but it doesn't cool the air. I'll have to put it in drive and start driving around before it gets cold again. Is my AC compressor going bad?
  7. Thanks for detailing your experience. I have the exact same truck, the 08 limited and I shared this with my boyfriend and he thought it was very informative.
  8. Hi, so when I have my AC turned on, it seems like the blower is.....struggling. That's the only way I know to describe it. The blower comes on at all speed levels, all position settings work, i.e. Floor, vent, combo. Sometimes I'll have it set to blow on the highest setting, yet, there will barely be any air coming out of the vents. And also I've had the AC on a med blower setting, and then while driving or while sitting there idling (it's happened in both circumstances) I'll hear the blower kick up a couple notches as if it's been restricted somehow and it just freed up. What's the deal?? Just need some suggestions on what it could possibly be. Thanks in advance!
