Ekim
About Ekim
Ekim's Achievements
  1. You are awesome. Thank you. I have decided that the Core has to be partially clogged, both hoses leaving the core were hot. I am going with a space heater that runs off the ash tray to keep the wifes feet warm :). I like the motors and power plus the ride is good but now now I am leery about buying another Edge due to this heater core b.s. keep up the great work, I am following you.
  2. Final question for you, I have pulled the actuator on the drivers side and manually moved the blend door to heat. The passenger side works and vents heat. Could the passenger side cause cold air to the drivers side? From the diagrams I have looked at I didn't think that was possible, also Is there a third actuator that I can't access without taking the entire dashboard apart? It would be nice not to flush if it is simply the passenger side hogging all the heat. If a 3rd accuator exist in the center pellum then I am stuck with a cost. I hope I am not annoying and confusing you with my words on text. I am greatly appreciative. mike
  3. Thank you for this post. Mechanics are telling me it is the heater core, it was replaced in 2019 and 3k to have a mechanic do it today. I am going to try the burp and if that doesn't work would you shy away from a flush simply for the reason it could damage the core or would you do it in hopes of fixing the cold air on drivers side?
  4. Returning back to this post. New heater core, new plenum, accuators work, I am guessing 2 things. Air in the line or somehouw the heater core is clogged. Driver side cold.
  5. hello I am here again searching for answers. A year ago I had to put into a full hvac (not sure of the name) vents... etc. that involved removing the dashboard and 3000 dollars. Now the same thing is happening again. one side of the car, passenger, toasty warm and the drivers side lukewarm. They at the dealership said It was a faulty actuator which they replaced for 300.00. We get the car back and head out to test it and absolutely nothing has changed. It goes back the same day and the tech is sick so now 5 days later they are saying it Is a bad heater core and they need another 1000+ to fix that. I bought the car from them 2 years to the day ago and the next day of owning the full hvac system "failed". Now they are saying the above and that the coolant if filthy. I put 4500 miles on that car in 2 years. Please, anyone have some advice on what to do? I think I shouldn't have to pay for the actuator... I also am surprised the coolant is filthy and what they say, the cause of the blockage in the core. One side of the car is toasty and hot! The other Lukewarm. Is there 2 heater cores? Thank you to anyone who wants to give me the time to help.
  6. That was one of the first things I did because that actually worked on my 2004 Silverado unfortunately it did not for the Edge. It is in the shop right now and I am hoping they find a rock or some such thing that is clogging it up. I didn't think of the Colant level and assumed it would have been checked out when the ford dealership did their check over. I am requesting to see the actual part they pull out so I can learn and pass on that information here. Plastic is not and should not be an option for moving parts.
  7. The flaps move and can be moved and the motor is running. They don't know for sure until they take the dash apart. I am hoping for a wire, mouse nest, or rock that is causing the flap to not open or shut out the outside air.
  8. Thank you for the response. That is what I was thinking as well so I called the service manager and asked him to explain and what he was saying is the Plenum is messed up and they had to take out the full dashboard to get at it to fix it. Each side has its own set of motors and actuators and apparently the driver side has failed. I am confused and I am researching
  9. Sad situation here. I just paid for a 2007 Ford Edge with 70,000 miles. We drove it for a total of 3 hours in 2 days and the heat on the driver side never warmed up. Since it was the weekend we brought it in on Monday, today the 13 of Jan, and heard back that it was a 1700 fix that they would graciously take 15% off since we only had it for 2 days. They say it is the Evaporator case that needs replacing. In all the forums I have looked at and read and researched where the heat on the drivers side failed did ANYONE mention the Evaporator case. Can someone please clarify this for me. Why would one side be good temps and the other not? This Edge has the dual temp controls. I would greatly appreciate any insight to this mess before I deal with the dealership. Thank you.
  10. Sad situation here. I just paid for a 2007 Ford Edge with 70,000 miles. We drove it for a total of 3 hours in 2 days and the heat on the driver side never warmed up. Since it was the weekend we brought it in on Monday, today the 13 of Jan, and heard back that it was a 1700 fix that they would graciously take 15% off since we only had it for 2 days. They say it is the Evaporator case that needs replacing. In all the forums I have looked at and read about the heat being room temp/ not hot on the drivers side and beautifully warm on the passenger side, did ANYONE mention the Evaporator case. Can someone please clarify this for me. Why would one side be good and the other not? This Edge has the dual temp controls. I am a newb here and a newb Edge owner, I would greatly appreciate any insight to this mess before I deal with the dealership. Thank you.
