My 2020 Ford Edge SEL has USB 2.0 logos next to the USB-A ports.
	That means that they should output 1.5 amps and 5.5 volts which equals 8.25 watts.
	If you have an iPhone 13, it is designed to charge at 20 watts.
	If you own an iPhone 7, it came with a 5 watt charger - but, it will charger faster with a 12 watt charger.
	USB 2.0 ports will not cut it in 2022.  Ford needs to get with it and upgrade to USB 3.2 with USB-C ports with 100-watts.
	I think my 2020 Ford Edge SEL with SYNC-3 has "smart charging" USB ports.  I need to study that.
	Ford "Power Points" (i.e. 12-volt 10, 15 or 20 amp cigarette lighter ports) can provide 120 to 240 watts.
	You can purchase USB cigarette-lighter chargers that output upwards of 36 watts - but, you would need to carefully purchase one that outputs the watts you need.  There are a lot of rip-off chargers available that do not output what they are advertised to output.
	Amazon Basics sells dependable products of various watt outputs (in my opinion) - just make sure you don't accidently purchase the wrong one.
