Hi guys,
	I'm a bit lost running through all the topics (the search function is not that good here  )
	I bought a 2007 Edge SEL.
	There was an aftermarket Kenwood system installed (old nav unit 7200).
	When deinstalling I saw that it was connected through ISO to the ford cable, no special AMP adapters, just the kenwoord > iso > ford cable. From the Kenwood was a audio cable connected in the SUB port (I guess that it's for the OEM sub in the back).
	Also there was a steering remote module from kenwood connected.
	No I want help for the following:
	If fitting an Android unit, does it need to be specific for Ford edge/f150? Does it need the canbus? Because in some forum I read that the SWC is working through the Android SWC cables and that is no need for the Canbus. Someone can confirm that? If thats possible then I can buy every double din unit.
	Is the Edge pre-amplified? How can I check that? From the Iso it looks like regular speaker wires but it's possible that there is a seprate amp from oem? If so, where can I find it?
	Are there some peeps here with a 2007-2010 android unit installed in a Edge SEL who can help me?
	On the crutchfield site I only can see that they recommend a adapter for the use of the OEM amp. But not sure if that's needed and that I even have a amp installed.
	Any help and recommandation for Android units are welcome.
	No need for Android auto/carplay, just regular Android with 2/4GB ram is enough. (1gb ram is to slow...)
	Thanks guys! Much appriciated...
	sorry for my bad English
