WillM
About WillM
628 profile views
WillM's Achievements
  1. We had the same issue, and thankfully I had purchased the extended warranty, so the repair was covered. That said, I would never buy a Ford again. The dealer charges $200 just to diagnose anything — even something as simple as a stuck seat belt. In my case, they didn’t even attempt to repair it. They just recommended full replacement. I’ve had issues with two seat belts: Front driver side gets stuck during the hot summer months. Rear seat belt stays stuck. I also had the tailgate lock fail, which they replaced. For a vehicle with under 50k miles, I’ve spent more on repairs than I did on both my Honda Pilot and Lexus at the same mileage. That’s unacceptable.
  2. I just got this code and what you experienced is exactly what I experienced. During cold start it starts rough. I also noticed that it need some coolant. So what was it? Should I take it to the dealer or local shop? I have extended warranty.
  3. This seems to be an issue because mine does the same thing during hot weather. Im going to try the stopping method and see or perhaps lower it a little. Thanks for sharing.
  4. the link is not found anymore. Can You tell me which part did you replace? Not having a liftgate to open is very frustrating. The dealer wants $200 just for the diagnostic and you have to leave the car for several days.
  5. What did you guys used for running the diagnostic and self test? What about to reprogram the RGTM? The liftgate on my edge is working intermittently. Had to take out the groceries from the inside several times. Its a pain.
  6. Since mine is doing the same thing yours was doing - literally the same, I could probably go ahead and replace the module. How much did they charge to reprogram the module? Thanks for the update.
  7. Did you guys find the solution? Mine(ford Edge 2018) has been doing the exact same thing for several months. Does the module need reprogramming? or does it needs to be replaced and then reprogrammed by Ford? Im stuck on the programming part. I can replace the module, but several posts are saying that they need to be reprogrammed. Will appreciate your help.
  8. I think mine has a GPS tracker connected to the OBD but I dont know how to activate it. I wrote to Ikon technologies and they have not responded. About the factory code, I did it yesterday and it worked. I did it quicker and with the doors closed. Thanks for the tip.
  9. I tried it and to your point, I had the door open so it didnt show any code. I checked the menu under “Keys” and it is showing 3 Admin keys but I only have two. Im assuming the dealer or the previous owner has/had the other. I will try again.
  10. Thank you for the reply. About the fob, I was able to get the second one programmed by a local locksmith. It was very quick.
  11. I just bought a 2018 Titanium but it didnt come with Remote Start. Any suggestion on installing a system that will work with the OEM fob? Also like many others here, only came with One Fob and no 5 digit factory code.
