Iroga
    4
Everything posted by Iroga
  1. It's already warm and I won't be able to check the operation. I'll try to connect another camera later. I'll check the wiring from the camera, of course. If you disconnect the rain sensor, then Forscan sees that it's not there. Can updating the camera firmware help?
  2. Did as recommended. Disconnected the connector. Rebooted the IMPA module. Enabled self-test. The result is in the photo.
  3. I will follow your recommendations. I have not made any changes.
  4. Maybe the problem is with the camera itself? Should I try replacing it? Or will it not help?
  5. I did this, but the error did not appear. I will try tomorrow when the temperature is zero.
  6. I tried to turn off the heater, but the result was the same.
  7. Thank you for helping. This is good news. I will try to do the same, but the temperature during the day is catastrophically rising to plus.
  8. Unfortunately, Forscan does not provide such a possibility as self-diagnosis of IMPA. Maybe it's just me? Version 2.4.15 BETA
  9. I wasn't happy with the light in the trunk at all. If the light isn't blocked, then everything is fine. But when it's blocked, it's hard to find anything. The lampshade is inserted into a frame made of textolite. I disassembled the right side of the interior to lower the ceiling. We connect to the rear right light. We place the lantern in the middle, carefully cut it out and insert it. We get the final result.
  10. Thank you. I will continue to investigate and look for the reason. Forscan does not find any errors.
  11. Yes of course, I checked it. Resistance is less than 1 ohm on the wires. The heating grid has resistance. There are no errors in IMPA and BCM.
  12. The camera heating suddenly disappeared. Tell me what I can look at and check?
  13. Iroga
    Hi guys.
    I'll be glad to read it the entire forum.
