Iroga
Everything posted by Iroga
Which model is the mat from?
Yes. It’s the same type of light as the one for the rear passengers. Power is drawn from the rear right one.
I found a connector that had already been used. I connected the wires based on their visual similarity and placement.
2016 Edge - A/C water Drain location?
Iroga replied to omar302's topic in Interior, A.C., Heat, Interior Trim
There are not many twitches. And if you try to add 0.25 to 8F 35, what good or bad can happen?
Maybe someone can give me some advice? Where is the air conditioner evaporator drain tube located on a 2019 model, 2.0? -
I wonder if there are two keys, will the code be displayed on the dashboard or not?
Thank you, that all makes sense. How to find the door code is what I don't understand.
That's how he got to Belarus. Yes, the car's VIN number.
Thank you, I understand.
Good day to all. There's only one key. For some reason, Forscan can't see the door code. As far as I understand, this is not the reason. 2FMPK4K96RBA03469. Can someone help me? Can I see it programmatically or do I have to physically look at it?
Iroga replied to ben senise's topic in Accessories & Modifications
Let's all write a friendly petition to resume beta support. Don't be shy, guys! https://forum.forscan.org/viewtopic.php?t=30415 -
Project - Get Active Cruise Control functioning
Iroga replied to andyh1108's topic in Accessories & Modifications
I activated the intelligent adaptive cruise control on my 2019 Ford Edge. -
How do you disable start/stop on a 2023 Edge? Auto Start/Stop Disabled PSCM 730-03-01 xxxx xxxx 00-- HVAC 733-01-05 xxxx x0xx xx-- This does not bring results. That is, it works, but a message pops up
Thank you. That's what I did. I opened it and disconnected it.
The door ajar indicator comes on when the vehicle's system detects that one of the doors (in this case, the rear door) is not closed securely. How can I temporarily disable it?
Car High Brightness Trunk Lighting Ambient Light Interior Decoration LED Wiring Free Automatic Sensing Tailgate Light Strip
There is a solution that is easier to implement. https://trusttosell.com/shop/car-high-brightness-trunk-lighting-ambient-light-interior-decoration-led-wiring-free-automatic-sensing-tailgate-light-strip/
Can anyone tell me the fundamental difference between the following values in Forscan? 1. Suppressed. 2. Continuous Only. 3. Self Test Only. 4.Fully Enabled. -
I managed to achieve a certain result, but the mode selection is unavailable. That's why no semicircles appeared. -
Thank you. I'll give it a try. I'd be interested in seeing results. And, if possible, I'd like to compare your configuration with mine. -
No, unfortunately there's no such option. Can this be activated in Forscan? This is not this? 720-06-01 xxxx xxxx x*xx Selectable Drive Mode: 0=disabled, 8=enabled 720-09-01 x*xx xxxx xxxx -
