Bunky
Everything posted by Bunky
  1. i believe now DCDC only deals with the battery. The powering up of everything is handled by a command from BCM to BCMC that has a relay that likely converts from 12v battery operation to HV battery dc to dc conversion if you push the start button (with or without brake pressed) but still seems to support HV battery is powering vehicle in "ON" (without pressing brake). It stated the DCDC controls voltage from 12v to 15v and my readings support. I cannot believe the system would step up the voltage to 13V from the 12V battery. I am on a journey.
  2. I have an occassional noise but it sounds more like metal to metal and keep thinking it is corrosion. I watched the video and mine does not sound like that. I P.S. I looked at the rotors and they are truly a disc and not the wider dics with that webbing between the outsides.
  3. I did this test. Voltmeter inserted in center console 12v port Vehicle off 12.4V Vehicle on without pressing brake 13.1V Vehicle on 15.2V One thought it is 13.1V is hv battery via dcdc. The 15.2v definitely means it is charging 12v battery but likely near full charge given high voltage, noco says 14.8 v is best for agm.
  4. Much to understand but i like the comment that the dcdc can output 260 A to 12V battery yet we have all these battery fails. It could jump ot anytime at least once. I still cannot tell if dcdc is powering everything in Accessory Mode like it is when running. Power is available but at some point it could be drained too. In this case the HV can act like an alternator even in Accessory mode.
  5. I am a Nauti Hybrid owner. I read the document and interesting that if you try to turn off vehicle while moving at 9 mph you have to press and hold or push 3 times. I am not sure what situation would need this (unintended acceleration?) but no driver would know this since I do not think this is in the owners manual. But, repeatedly pushing does sound like something one may try when desparate. The owner's manual calls the ON condition (not with brake applied) as "accessory" and in the vehicle it calls it "Full Accessory Mode" and brielfy displayed briefly on 48 in display. I assume the word "full" is to emphasize the HVAC and other aspects are still active since I am sure it is a huge drain on battery. My question is when in this mode what aspects are powered by 12V battery and what is powered by HV battery? Funny there is no option to get residual charge in HV to jump start the 12V battery. I guess it could be abused and damage the HV battery.
  6. My question was regarding getting to accessory mode since we do not have a key to put in ignition.
  7. In the instructions, I assume for my 24 Nautilus Hybrid, I just push start button without pushing the brake so it is in full accessory mode.
  8. Thanks for update. How on earth do they think the OTA is possible when you look at all the conditions (SOC, battery voltage, profile mode, etc)? If OTA was so much better, why not do it that way at the dealer? They should be able to force an update through secret commands. I watched a tech try to do it mobile and it looked primitive. = downloaded to tool, build USB key, then insert in car USB and then start update. In my case, it failed to recogize the key and the tech stopped. I considered that as a blessing. He was able to get window fix and the GWN done but balked on the APIM. I have noticed it takes MINUTES for the vehicle to recognize a USB key (like a music USB),
  9. I do not like these kind of recalls in that I would guess engine performance would be reduced.
  10. To get this update, do you have to exhibit the problem? It would be silly to wait until the problem happens to get it updated?
  11. All signs that Ford is trying to manage warranty costs. For us Lincoln Nauti owners, a software update would likely reduce warranty costs while mechanics try to debug software issues.
  12. Yeah i noticed but could not easily convert. I did realize thr camera changed settings. Google photos is crap as basic pic editor.
  13. It finally worked for me once I understood what they were describing, The image in the manual is poor and misleading - just like the image pointing to the interior fuse box. The access slot referenced is a slot underneath the power ports in the rear section of console. It is molded into the console as a little open top compartment. It is easier to feel to find rather than see if you are sitting in drivers seat. It is black so will not be obvious to see if in the garage. Once you insert the each fob, it takes a some seconds (more than one expects) to see the code display on the 48 inch display area where other messages appear (seat belts, etc). The delay was long enough that I initially thought it did not work and does not last that long. I suspect you are not inserting the fobs in the slot.
  14. I believe that until the 3Q software update is out, customer should not link their fobs to their profile. It causes others like the easy entry exit. I can save presents with profile without linking fob.
  15. Here is another document. NHTSA Recall 24V-597 Ford-Lincoln Recall 24C24 - Global Closing Unattended Window Pinch.pdf
  16. If you smell exhaust in the interior, you obvious have a leak somewhere and should identify and fix the leak before worrying about engine performance. For this, I do not think you need a specialized mechanic except it should be someone with a good nose. A Ford dealer may have specific experience if it was a common issue. If it happens at certain times (like idle), you could mention that and if a rear passenger smells it more. I personally would guess it is in the rear somewhere or related to something bolted to the floor like the seats..
