rpspiker Posted August 28, 2018 Report Share Posted August 28, 2018 I purchased a Roadmaster Diode 7-Wire to 6-Wire Flexo-Coil Wiring Kit (RM-15267) to connect to my motor coach to use the 2018 Edge Titanium's rear lighting while flat towed. Has anyone done this. Are there any issues with connecting to the LED lights? The instructions direct to remove the rear light assembly and install the diodes in the cavity between the car body and the light assembly; then run the cable up to the front of the vehicle to the socket mounted in the grill. I'm thinking it would be easier to find the wires at the front of the vehicle and install the diode inline near the the fuse panel. Any thoughts? Universal wiring kit with 7- to 6-wire cord install instructions 85-5501.pdf Quote Link to comment Share on other sites More sharing options...
