code p0012 and p0022 with low engine pressure alarm and grinding noise
kkelleher
i have a 2014 ford edge awd with v6. i just got it smogged 4 days ago and today i had a warning light come on for low oil pressure, its throwing codes p0012 and p0022 both cam sensor banks over retarded. after a min or two running i hear like a squealing or grinding coming from engine. I'm just trying to see what is the most common problem with these issues are. I doubt both cam sensors go out at the same time
  • Sad 2
Welcome.
The low oil pressure will make the Variable Valve Timing inactive and throw  the codes that you have.
The low oil pressure and noise you describe makes me think the engine is trashed.
What's the mileage?
What's the service history, oil change interval?
What oil and oil filter used?
