Vance correa Posted July 26, 2025 Report Share Posted July 26, 2025 (edited) My power steering belt snapped. So I took the power steering belt off, and the serpentine belt, tried to replace the powersteering belt but that’s the hard part could’nt do it, I put the old serpentine belt back on, but then I came across an issue. When then to replace the powersteering belt i cranked the crankshaft counter cloxkwise a little until I heard it crank 3 times then after putting the serpentine belt back on I tried to start the car but it wouldn’t turn. I believe the car went into anti theft system mode. I tried hard resetting it by disconnecting the battery and trying the key fob but all of those did not work . Edited July 27, 2025 by 1004ron Quote Link to comment Share on other sites More sharing options...
1004ron Posted July 27, 2025 Report Share Posted July 27, 2025 Turning it counter-clock most likely caused it to jump valve timing - does it turn clockwise using a wrench? I expect you'll need to pull the timing covers and re-time the cams. Quote Link to comment Share on other sites More sharing options...
