Edge4Me Posted January 3, 2011 Report Share Posted January 3, 2011 Hi, I'm having trouble using the Vivaz Pro with SYNC, It looks like paired OK, I can voice calling someone thru SYNC and it call them on the phone itself but I can not hear or talk thru the SYNC System ???? Same with incoming, I can hear it ring thru the SYNC but as soon as I pickup, no sound !!!!! HELP !!! Quote Link to comment Share on other sites More sharing options...
akirby Posted January 3, 2011 Report Share Posted January 3, 2011 Hi, I'm having trouble using the Vivaz Pro with SYNC, It looks like paired OK, I can voice calling someone thru SYNC and it call them on the phone itself but I can not hear or talk thru the SYNC System ???? Same with incoming, I can hear it ring thru the SYNC but as soon as I pickup, no sound !!!!! HELP !!! Make sure the phone is set to use Sync for audio. Also try adjusting the Sync volume during the call - it may just be turned all the way down. If that fails try deleting and re-pairing. Quote Link to comment Share on other sites More sharing options...
Edge4Me Posted January 6, 2011 Author Report Share Posted January 6, 2011 Make sure the phone is set to use Sync for audio. Also try adjusting the Sync volume during the call - it may just be turned all the way down. If that fails try deleting and re-pairing. How to "Make sure the phone is set to use Sync for audio" ?? Isn't pairing them by bluetooth will take care of that ? Do I need to do something on the SYNC ? I'm lost on this one ..... Quote Link to comment Share on other sites More sharing options...
akirby Posted January 6, 2011 Report Share Posted January 6, 2011 How to "Make sure the phone is set to use Sync for audio" ?? Isn't pairing them by bluetooth will take care of that ? Do I need to do something on the SYNC ? I'm lost on this one ..... On my iphone it gives you a choice of where the audio goes - to the connected bluetooth device (sync) or to the internal speaker. I have no idea what options your Vivaz has or where it would be. You'll have to RTFM on that one. Quote Link to comment Share on other sites More sharing options...
