Custom Search
Sign In  Log in with Facebook
Create Account
Click here to signup now
Guest Message by DevFuse
Check out the Ford Edge ST Forum Here
Valve sticking on abs system
  • Please log in to reply
2 replies to this topic
#1 OFFLINE   Tdownton
Tdownton
    New Edge Member
  • Edge Member
  • 2 posts
  • Region:Decline
  • Edge's Year:2011
Posted 20 December 2016 - 07:01 PM
We just had our 2011 Ford edge in for the Booster replaced, how four months later the same thing happened. We took back to dealer and they tell us there May be a valve sticking on the abs system.
#2 OFFLINE   Tdownton
Tdownton
    New Edge Member
  • Edge Member
  • 2 posts
  • Region:Decline
  • Edge's Year:2011
Posted 20 December 2016 - 07:03 PM
They ran diagnostics and stated "hcu on abs system may have a valve sticking will need to replace". Cost is approx $1,000.00
#3 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • Edge Platinum Member
  • 2,728 posts
  • Region:U.S. Mississippi Valley
  • Edge's Year:2011
Posted 23 December 2016 - 07:26 PM
If it was my Edge I would have the brake system fluid completely replaced with new fluid then find an isolated road and perform some heavy braking repeatedly for several runs then even run another full brake fluid replacement.   This may and I say may correct the problem.  The question here is have you ever had the brake fluid completely replaced in your Edge?   Maintenance means replacing all fluids.
