Used Ford Edge Throttle Body Spacer
Originally 99.95 WILL TAKE 50$
Easy Install takes 15 min
Steeda's Billet Aluminum intake spacer is designed specifically for the new Ford Edge. Made
from Billet 6061 aluminum it is designed to give you more plenum volume for increased
horsepower. The swirl design helps promote airflow by breaking the surface tension of the
incoming air. An increase of horsepower and fuel milage can be seen with this part. Kit includes
instructions, gaskets and mounting hardware.
Note: It is necessary to trim Steeda's Cold Air Kit by 3/4 of an inch if combined with Steeda's
Throttle Body Spacer.
Product Benefits
•Increased horsepower and torque
•Increased fuel economy
•Simple installation
Vehicle Fitment
2010 Ford Edge
•2009 Ford Edge
•2008 Ford Edge
•2007 Ford Edge
Used Ford Edge Cold Air Intake w/ New Filter
Originally 299.95 WILL TAKE 200$
Steeda's Cold Air intake system for the Ford Edge will give your Edge extra spunk while also
helping with fuel mileage. Steeda went the extra mile with its design by allowing it to be used
with or without a custom tune.
A removable insert is provided which when retained in the mass air meter assembly will allow
your Edge to use this intake system on the factory Ford tuning. Removing the insert requires
you to use a custom tune for the vehicle to run properly. With or without the insert you can add
additional power gains over the intake alone with custom tuning using our SCT Xcalibrator 3
tuners.
Expect gains of 10 to 12 horsepower from the intake system alone using the insert and stock
tune. The ultimate gains in performance result from the cold air and tune combination. Testing
has shown gains of up to 35hp and 27ft/lbs of torque at the wheels when running this system
without the insert using a custom tune.
Steeda's Edge Cold Air Kit includes a stainless steel airbox with built in velocity stack, billet
mass air w/sensor mount, and Pro-Flow Air Inlet Hose. It mounts in the factory location and the
stainless steel heat shield features a rubber seal which seals the airbox and isolates it from engine
heat. In addition the Pro-Flow Inlet Elbow was designed to accept the factory noise resonator
to keep inlet noise to a minimum. A Steeda exclusive! Our lifetime use air filter can easily be
cleaned and re-oiled making maintenance a snap.
Product Benefits
•Lifetime Warranty - Backed by a trusted company that has been in business for over 20
years
•Built in Velocity stack compresses and straightens incoming air, eliminating turbulence
across the MAF for greater gains than just having larger MAF housing and better throttle
response.
•Included heat shield isolates air entering the filter from engine bay air reducing air
inlet temperatures resulting in better power. Unshielded kits lose power in real world
conditions due to reduced air charge density and timing reduction by the computer
•Securely mounted to vehicle - Will not vibrate, bend or cause damage like unmounted
systems
Vehicle Fitment
•2010 Ford Edge
•2009 Ford Edge
•2008 Ford Edge
