L0lboubou
Everything posted by L0lboubou
2012 SEL LED Headlights
L0lboubou replied to kshawks's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
this is good or not? http://www.ebay.ca/itm/2015-New-60W-7600LM-Set-Cree-LED-Headlight-30W-Bulbs-H7-9005-9145-9006-9012-/281404883868?pt=Motors_Car_Truck_Parts_Accessories&hash=item418509c39c&vxp=mtr or http://www.ebay.com/itm/1Set-45W-9000lm-9012-White-6000K-LED-Car-Headlight-Kit-Front-Lamp-Bulbs-CE-ROHS-/271756529465?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3f45f38f39 -
cant wait to see thoses pictures!
did you use the glossifier plastidip on the black plastidip? Thanks
@scottk can you post some pics please? Thanks
What I dont like is to put some wires in a brand new car (more or less 40 000$...)
But if i just want ro change the accent light by more powerful ones but i dont want to have drl on these, it is possible? I just want that these accent light bright more with no more wiring.
but with daytimebrightlites DRL, i read that its not just plug and play with the OEM plug from factory accent light. It is true? I just want to change these accent light with DEL one but with nor extra wiring. (i want to use the OEM plug) Thanks.
I read that the chrome insert cant be paint... So it's not true!? It is expensive? Thanks
did you wrapped the all grille or you painted it ?
I went to the gas station and i full the tank and 60L and 81$ later, the tank is full. So I did 556km and the DTE said i was ok for another 43km. There is a picture of my DTE after i fulled it (i did not reset it manually.)
3.5L V6 (so not ecoboost) I will post a picture tonight but rhis morning, the yellow low gaz indicator showed me the message and i am at 540km. It is weird because the gauge seems to be not quite to the E line... It is just a first warning or i have to go to the gas station soon? (First time with my edge and with electronical gauge)
Ok thanks. I have FWD. I will let you know this week when my gaz light will turn on. Do you still want a picture?
What do you mean by DTE? It is the computer gaz average ? I did already 480km and the ford system says that i can do approximatly 100km more. It says too that i do 11.1 L/ 100km
With my new Ford Edge SEL 3.5L V6 2014 i will do 580km on the first full tank from the dealer. (half road and half city). Just to let you know that my best firend is the cruise control ! I suppose i will do better after the first 1000 km. How many liters the gaz tank have ? Thanks.
with these light? (seems to be like oem plug fit) http://www.ebay.ca/itm/151274843861?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
canadian drl hid
L0lboubou replied to Jocelyn Castro's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Thanks for this information! -
canadian drl hid
Thanks a lot for you time @normcloutier Just to be sure, I know you have the new LED DRL so thats why they are on on the first picture, but on the second picture, this the front turn signal are on as OEM DRL changed by the dealer when the car is running and finally, the third picture is night mode? All correct? Finally, for the 35w HID 9012 bulb kit, do you have the hi-low kit or it's juste low beam only? (because in the 9006 bulb kit, it's only the low bulb...) It is sad to lose hi beam with hid... Thank you -
It is posible to just plug the aftermarket DRL with the OEM plug and not wire the turn signal and the drl mode? Just to replace the OEM strip light thats it?
canadian drl hid
In fact, I never saw a Ford edge with factory HID with front turn signal DRL. LOL Thanks for your time, i will wait your pictures. -
Hi, I would like to know what do you think about this technologie ? LED HEADLIGHTS PLUG AND PLAY BULB. http://www.ebay.com/itm/2014-New-60W-6000LM-Set-Cree-LED-Headlight-30W-Bulbs-H11-H8-H7-H4-9003-9005-9006-/281404883868?pt=Motors_Car_Truck_Parts_Accessories&hash=item418509c39c&vxp=mtr 3000 lumens/ bulb for a total of 6000 lumens for the pair ! (not bad) and all that with the OEM plug. So we don't need ballast or anything else and it's just plug and play with no wires extra! It is a dream or it is real? Does it work or not? It is dangerous for something? (electric, beams, plastic, heat, etc.) Let me know because I know what is HID and the power of the HID, but LED headlights is a new technologie for me and I never see that.
canadian drl hid
@normcloutier can you pos a picture or a video of the drl in front turn signal and with the 4300k hid? Thanks a lot!
