                Posts51
Everything posted by Dukhaykh
	  Wiring Aftermarket Camera in OEM plugDukhaykh replied to Dukhaykh's topic in Accessories & Modifications Many thanks for your support and providing these valuable insights. Regarding the installation process, I found different way on the Youtube and it worked well with me without the need for drilling or removing the Ford emblem.
	  Wiring Aftermarket Camera in OEM plugDukhaykh replied to Dukhaykh's topic in Accessories & Modifications Many thanks for your time and support. You are right on first point you mentioned about the signal format and compatibility. I figured out how to connect the camera cables with the OEM cables but somehow the video quality was not good enough. I ended up by wiring new cables to the new Android screen directly and it is working perfectly.
	? Hey there, I want to connect an aftermarket camera on my OEM previous camera plug. Any ideas where I connect the power and video wires! I also found digram for Rear plug wiring diagram to help in this case. Any support would be appreciated.
	Your right, Update; I did remove the rear did and its axels. After that I balanced both my rear tires. Now everything is okay ?? attached how the car looks like without dif and axles ? Next project will be removing the PTU.? IMG_0824.MOV
	Hello, My Edge AWD, I took off the drive shaft to make it runs as a FWD. I am wondering now if it’s possible to remove the rear differential & axles without issues?! If it’s possible, are there any possible effects on car stability & traction etc; Thanks in advance ☺️
	  NA 3.5 swap! - Taurus Sho engine on 2014 Ford Edge ?Dukhaykh replied to Dukhaykh's topic in Accessories & Modifications Thank you all for your great advices. Hmmm, What about just installing one of the v6 turbo?! My be a rear mounted one. My main goal is to gain some power around 50hp ?
	Thanks a lot Omar, Very glad to see these posts definitely these info will help me. ? I have a hope that this issue can be fixed by only programming the steering wheel module. will keep you updated.
	Thank you Omar for your feedback. Will read the post you shared and see what I can do.
	I have a 2014 SEL Edge. I have installed an Edge Sport steering wheel with (+/- Paddle Shifters). I have currently shifters (+/- buttons on the shift lever). After the swap, unfortunately I figured out that the Paddle Shifters on the steering does not work! Any idea how to get them work by using FORscan maybe? Do I need to make wiring modifications? Appreciate any input on this. Thanks.
	  Comprehensive List of Possible Forscan Mods?Dukhaykh replied to ben senise's topic in Accessories & Modifications Tried that out but I it was very bad idea. Unfortunately this way didn't work and now I can't return it to the factory values! I keep getting error when I hit “Write”: "[17:12:41:891] Service procedure has been interrupted". After communicating with FORScan Support they replied; :(
	  Comprehensive List of Possible Forscan Mods?Dukhaykh replied to ben senise's topic in Accessories & Modifications Thank you @omar302 for your reply This is a very disappointing ?
	  Comprehensive List of Possible Forscan Mods?Dukhaykh replied to ben senise's topic in Accessories & Modifications Hi, Can I adjust the time of the Ford Edge 12v powerpoint timeout in 2014my? Would like the 12 volt power socket to go off after a set time, currently it's on permanently, any idea of this can be done ? Thanks
	@Special_K Thank you for your feedback, I am thinking also to find out some Mods by Forscan May be! I usually take off the ABS fuse especially during race ? because I can see the difference in power ✈️ . I have driven my car for almost a year without any problems. I even installed a switch inside my car connected to the fuse to turn it off/on easily ? The problem with the fuse when you take it off the ABS system will shut off too. I am thinking now to use my current switch setups on the back clutch instead of using the fuse. Fuse box attached;
	I tried also to pull the fuse for ABS and I got different msg on the dashboard as you can see below: AWD off But as above picture, when I pull the back switch I got msg: Check AWD ! I don’t know if the first alarm means the ptu is off completely!
	Thank you for your great information, I found the connector on the same place you described above and pulled it out. It is showing now on dashboard lights saying Check AWD. Now its FWD only. The question now, Is the ptu now still working and moving the drive shaft? If yes is there a way to stop it too ?
	I also did Pull the AWD fuse and it turned off but it also turned off the ABS and traction control!?
	I tried to find the connecters but with no luck ? any other suggestion?
	Its the same part. It is called "Vapor Canister Purge Valve". I changed mine about month ago costs only around $25
	Thank you for your feedback, will try to find out the connector place ?
	My 2014 ford Edge is equipped with AWD, i wanna turn AWD off and just use FWD temporary, Is there any way that i can turn AWD off?
	  What have you done to/with your Edge/MKX today?Dukhaykh replied to WWWPerfA_ZN0W's topic in Accessories & Modifications A friend of mine did something with the fuses and made the AWD comes OFF (Dashboard lights says AWD OFF) and FW only works now without even removing the driveshaft! that means this thing is also controlled electrically.
	  What have you done to/with your Edge/MKX today?Dukhaykh replied to WWWPerfA_ZN0W's topic in Accessories & Modifications Removed the driveshaft on my AWD and now it’s FWD ??.
	  What have you done to/with your Edge/MKX today?Dukhaykh replied to WWWPerfA_ZN0W's topic in Accessories & Modifications Yes you are right the sound too low you have to insert the speakers ? inside your ears ? Yes sure will keep them still new and as I know its so expensive.
