Edge-y
Everything posted by Edge-y
  1. Alright guys. I have a problem. I installed some LED headlights on my 2014 SEL. I’ve done this numerous times on vehicles with and without projector headlights and never had this problem before. In the pictures you can see a hard line where the light cuts off. This should not be happening. And I’ve done everything to make sure that they are 100% in correctly. Has anyone else had this issue? Any advice is greatly appreciated.
  2. So I’ve made a discovery. I normally don’t let my vehicles get below a quarter tank of fuel for obvious reasons. Well, I did it once last week and noticed that it stopped acting up when the fuel was very low. Filled almost all the way up from empty and it stated acting up again. So, I repeated the process and got the same results. It doesn’t act up when it’s running on low fuel. Still think it could the purge valve failure?
  3. Can I pull codes even with no check engine light?
  4. 88k miles. No lights on and haven’t checked codes. Haven’t looked at the security light because I didn’t think to do so. Not sure if the purge valve has been replaced as I just bought the car 3 weeks ago. I noticed the prolonged crank after I bought the car.
  5. Did you ever find a remedy? Having the exact same issue with my 14 SEL.
