I know many of you have been waiting quite sometime. I have received all three of the updates for my Ford Edge. I can say my front camera has been working consistently now and the ambient lights do not turn off on their own anymore.
+1 on my 2021 Ford Edge ST. I brought it to the dealership on June 3rd, 2022 and left it for the day there. They could not fix it as there was no fix for it. They have advised that there was 2 other Edges on their lot for sale that have the same problem. They have reached out to Ford Engineering and still waiting for answer, which is fine. I just hope when they find a solution it is the correct one. My work order is still open at the dealership.
Thank you!!! I do appreciate this! I never realized how much I enjoy the front camera until it is gone
**UPDATE**
I am currently at the dealership to get my oil change done. There is a recent recall (Ford Recall #: 22S14), apparently this is a full day job at the shop, and should correct most of the issues. I am going to book it and see if this works.
Hello,
Though my question is not related to the temperature display, it is related to the newest over-the-air updated that was released on May 4th, 2022. Has anyone noticed that their front camera only work’s intermittently? I have done the APIM soft reset and this does not seem to fix the issue.
I ordered this first, this is not a waterproof device and the circuit board is completely exposed from behind. I also tried hooking it up the first unit I received did not work and the replacement one worked. However, when it is plugged into the trailer wiring I loose all of my sensors.
I am thinking of purchasing a F1 style rear fog/brake light to mount around the rear hitch when it is not in use. The light would blink three times quickly before going a solid red. Now I am not looking to get into the legality of it, I already checked and it is legal where I live. I am more curious to know how to tap it into the lighting for my 2021 Ford Edge ST. This is the light I am looking at. Any tips would be helpful. ?
https://store.ijdmtoy.com/products/universal-smoked-lens-15-led-rear-bumper-diffuser-rear-fog-light-kit-for-car-suv
thank you Gadgetjq,
I looked up the fuses and fuse 35 is the 5 A Passenger airbag deactivation indicator and fuse 26 is the 30 A Front passenger door window and mirror. Front passenger door module. Front passenger lock indicator. Front passenger switch illumination.
I have not checked if it is always hot or not, as I am waiting for my micro fuse taps to arrive.
That is a really clean set up!! I just set up my dash cam on my 2021 Ford Edge St. I am to the point where I need to hard wire it, I want to use fuse taps into the fuse box under the dash. I need to find a fuse that is always hot and one that is powered when the car is on! Any advice?? Thank you in advance ??
Hello Everyone,
New member here and I just purchased a 2021 Ford Edge ST with the 401a package in black. Doing a lot of research in the Internet and I cannot seem to find a ton of information on the 2021 ST. My main question is does the 2021 model year still include the adaptive headlamps? This is a Canadian car as I am in Canada. (I know this topic, has been beaten to death) I can not find an answer for this anywhere. My dealer says it does but they checked the build sheet and says it is standard on the 401a pkg. my window sticker makes no mention of this. Also there is no option for this in the menu on the dash or on the Sync 4a.
Any help would be appreciated!!
RM
