Myx
Everything posted by Myx
  1. Hey! I think you need to check the operation of the retractor relay on the starter. It is possible that the power contacts inside this relay have worn out from time to time and it just needs to be replaced if it is sold as a separate spare part.
  2. ATTENTION! You do everything at your own peril and risk! Be sure to back up your settings before changing. Full version of FORScan required. We go into the module programming mode, select the BCM module and the AS BUILT configuration mode. We need to change two options: 726-13-01-0000-XX - responsible for the front turn signal lamps. 726-14-01-0000-XX - responsible for the rear turn signals. XX - leave some numbers unchanged. Four digits are replaced with zeros. Initially there 0101. These changes turn off the burnt out lamp indication by fast flashing at a rate of 160 times per minute. You can search Google for the word Hyperflash.
