smcmurray
About smcmurray
smcmurray's Achievements
Rookie (2/14)
Rare
Rare
Rare
Rare
Rare
Recent Badges
The long cranking issue is still resolved with the new injectors. That's likely all that was needed after all.
- 32 replies
- hard start
- ford edge
(and 2 more)
Well, it solved the issue temporarily. The new pump was 1500$. They initially they wanted $2000 but after gong all Karen on them about the 500$ for the prior incorrect diagnostics and solution they reduced it to 1500$. It started to happen again before Christmas but we weren't driving as much and waited until after the holidays anyway. We took it back and again there were no codes and they claim the fuel pump is still okay and suspect a leaking injector was causing it to flood. It was 600$ to check the injectors (by looking in the cylinders with a borescope for gasoline) and 1200$ to replace them all. We choose the replace option. It's only been a week but so far so good. I'm extremely annoyed with the dealership for basically throwing expensive parts at the problem. The whole reason I took it to them was for better diagnostics to pinpoint the cause. Despite their claims that it needed a fuel pump it's awfully suspicious that the symptom would recur so soon after replacement.
- 32 replies
- hard start
- ford edge
(and 2 more)
Problem solved. To try the cheap stuff first we changed plugs (it was due anyway since it's now at 270,000km) and the purge value since it was also inexpensive and easy to reach. We took it to an independent mechanic and they said they could not find anything wrong but they didn't have the ford specific scanners or tools to check things like fuel pressure. They replaced the PCV hose but that made no difference. We took it too the dealer and they said no codes, but the purge valve was leaking and the battery was low (I thought it odd to even test the battery since the issue reported was cranking excessively). We had them replace the purge valve (maybe the aftermarket one was bad) and suggested they test it by getting it up to operating temperature and trying to start it. The long start was still there when we picked it up but it was after hours so we had to reschedule. We then changed the battery on the off chance some low voltage condition could be contributing and the battery had a 2018 date on it. We dropped it off with them again and complained about their poor diagnostics and lack of follow up testing. We did not want them to just throw parts at it and hope for the best. This time they found a problem with the fuel pump so we had them change it. We didn't want to reward them with the extra business, but wanted to be able to hold them to account if they were just blindly replacing parts. It's been over a week with the new fuel pump and it's back to starting correctly. It still seems odd that the symptom only appeared when the engine was warm, but it's nice to not get all the stares in the parking lot when it cranks over so long before starting.
- 32 replies
- hard start
- ford edge
(and 2 more)
Unfortunately no longer available. Not on Android.
- 32 replies
- hard start
- ford edge
(and 2 more)
A basic bluetooth code reader. No current codes and no saved codes reported.
- 32 replies
- hard start
- ford edge
(and 2 more)
Any updates? I've watched ours more closely and it does match your symptoms. First start in the morning is quick and restarting after a few minutes is fine. But anything 1 to 3 hours takes a lot of cranking. Maybe some kind of vapor lock from the hot engine?
- 32 replies
- hard start
- ford edge
(and 2 more)
Did you get this solved? Ours occasionally does this as well sometimes hard start when cold in the morning after sitting overnight and other times when it's warm. I've seen others suggest turning it on, but not trying to start for a few seconds to give the fuel pump time to pressurize the system. The suggestion there is fuel drains back and the solution is to replace fuel pump. Those are costly and labor intensive so I'd like more confidence that's the issue before diving in.
- 32 replies
- hard start
- ford edge
(and 2 more)
07 MKX 8p maps torrent burning Q's
smcmurray replied to BrentMKXElite's topic in Audio, Backup, Navigation & SYNC
A guy in Vancouver is selling the 11P update. He doesn't list prices so I won't say what I paid but it is a lot less than Ford wants. Here's the ad http://vancouver.kijiji.ca/c-cars-vehicles-auto-parts-tires-audio-GPS-Latest-GPS-navigation-DVD-CD-maps-disks-for-your-vehicle-W0QQAdIdZ420251611 -
How to use Nav. while driving?
smcmurray replied to maddwakester's topic in Audio, Backup, Navigation & SYNC
I think it's too bad Ford didn't link the access to navigation with the presence of a passenger. The airbag system knows if a person is riding shotgun so the Nav system should be active while in motion if you have a front seat passenger. -
I wonder if they have done a proper pricing evaluation on these upgrades. It seems like most people will skip or not upgrade at all rather than pay $200 for the update. I would think a lower price such as under $50 would get a lot more people upgrading and in the end produce even more revenue for Ford/Navteq. They should even look to the lifetime subscription model offered by Garmin for their portable devices. You pay up front or monthly or even yearly, but marketing would be something like for only $4 per month you can keep your maps up to date. The time and effort and cost has already been invested to create the map data. Selling more DVDs at lower cost would net more profit than not selling DVDs at all. In general, the reason people feel better about stealing software than hardware is that the copy is free. Yes, the content is costly and took a lot to create, but the copy is free. It costs Ford nothing when a person that WILL NOT PAY finds a copy somewhere. They haven't lost a sale nor do they have to produce new content or even a new DVD to replace the stolen one. ps are the 'used' ones on ebay also 'stolen' as the person selling may have installed from the DVD and is now re-selling that electronic content to someone else? Basically they are keeping the copy and selling the original at a discount. -
After more trips to the dealer and having them finally hook up the computer while it was malfunctioning they decided to replace the pinch strips. That did not work so they finally broke down and replaced the closer motor. So far, about 5 months, it's been working. Just annoyed it took that long for something that is that obvious. There were only two possible failure points so it should not have taken that long to resolve.
Not yet. Which fuse?
