Wiring after market Sub
I'm adding a powered sub and component speakers (front) to my wife's 2010 SEL. Any ideas or thoughts on install?
Also, I found the factory premium sub harness but was wondering if anyone has used it for aftermarket subs.
Any luck with LOC's?
I see this question was never answered in 2010 and I am wondering the same thing in 2015 as I try to wire my Edge with aftermarket Sub. Any answer would be appreciated. Thank you.
Im not too sure if it is the same as the 2007, but if it does have a origional box like mine does, the install is really easy, all you ahve to do is take the right rear panel off and remove the old sub, and you can use the same adapters, only thing that will be changed is where the amp receives power.
