gjas24 Posted September 1, 2016 Report Share Posted September 1, 2016 (edited) I have a 2016 Edge Titanium 2.0 purchased only a week ago. I hooked up my jetski trailer and have no lights at all, then tried a 4 pin tester and still got nothing from the plug. The only info I can find about fuses is 1 fuse under the power distribution box labeled "Trailer Lighting Module". This fuse is confirmed good with a multimeter.... Is there any other fuses for the lighting itself? Edited September 1, 2016 by gjas24 Quote Link to comment Share on other sites More sharing options...
jmr061 Posted September 1, 2016 Report Share Posted September 1, 2016 If the fuse is good that is all the end user can check for. Sounds like a dealer visit to me. Quote Link to comment Share on other sites More sharing options...
gjas24 Posted September 1, 2016 Author Report Share Posted September 1, 2016 So after a little digging in fords documentation I figured out the problem.... The connector from the exterior wiring harness to the interior wiring harness was not connected. (I took a picture to help other people out but it came out really dark for some reason.) The two connectors for the trailer plug pigtail are located under the passenger side rear bumper. There is a plastic cover right next to the exhaust tip, remove the two screws into the bumper and you can pull it back to see the wires. It was just hanging there disconnected. 1 Quote Link to comment Share on other sites More sharing options...
jmr061 Posted September 1, 2016 Report Share Posted September 1, 2016 Wow. Great quality. I would have assumed it was all hooked up but guess not. Jeez Quote Link to comment Share on other sites More sharing options...
