Brian r Posted March 7 Report Share Posted March 7 13 hours ago, Wubster100 said: 1. Yes add a new wire into the BCM connector and run it to the cup holder. 2. Yes. I think I got power from the auto start/stop switch. 3. What year do you have? SYNC 4 or SYNC 3? There will be more changes. There is a change in the BCM to enable the LIN for the lights. There are changes in the APIM to enable ambient lighting and to select multicolor or single color.  I did not make any harnesses. I just soldered and tapped wires. I did not use a harness for the cup holders, I just used small jumper wires / breadboard wires into the pins of the cup holders. I have a 2024 which has sync 4. Do you remember the changes you made with forscan to the bcm and apim?  1 Quote Link to comment Share on other sites More sharing options...
Brian r Posted March 7 Report Share Posted March 7 18 hours ago, Wubster100 said: 1. Yes add a new wire into the BCM connector and run it to the cup holder. 2. Yes. I think I got power from the auto start/stop switch. 3. What year do you have? SYNC 4 or SYNC 3? There will be more changes. There is a change in the BCM to enable the LIN for the lights. There are changes in the APIM to enable ambient lighting and to select multicolor or single color.  I did not make any harnesses. I just soldered and tapped wires. I did not use a harness for the cup holders, I just used small jumper wires / breadboard wires into the pins of the cup holders. I made the change in the apim to a 2 from a 3 thinking that would enable the menu in sync but it didn’t. I haven’t installed the cup holders or ran the Lin wire from the bcm yet because I want to make sure I can get the menu to show up first. Can I get the menu on sync by changing the apim before the cup holders or wire from bcm is installed or does everything need to be installed to get the menu to display.  1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted March 7 Author Report Share Posted March 7 1 hour ago, Brian r said: Can I get the menu on sync by changing the apim before the cup holders or wire from bcm is installed Yes, you can enable it on screen. I will try to find the changes needed. 1 Quote Link to comment Share on other sites More sharing options...
Brian r Posted March 9 Report Share Posted March 9 On 3/7/2026 at 4:38 PM, Wubster100 said: Yes, you can enable it on screen. I will try to find the changes needed. Any help you can provide is appreciated.  I’ve scoured the internet and can’t find the forscan changes that need to be made.  1 Quote Link to comment Share on other sites More sharing options...
Brian r Posted March 14 Report Share Posted March 14 Hey Wubster, Were you able to find the changes you made with forscan to enable the menus on screen? 1 Quote Link to comment Share on other sites More sharing options...
Brian r Posted March 19 Report Share Posted March 19 On 3/7/2026 at 4:38 PM, Wubster100 said: Yes, you can enable it on screen. I will try to find the changes needed. Any luck finding the changes. Â I got it on the screen by changing the apim. Â Just not sure of the changes to make in forscan for the bcm. Â 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted March 20 Author Report Share Posted March 20 SlaveExists_ALM_Cfg It should be 726-65-01 xxx*-xxxx-xx 0 = absent 1 = present 1 Quote Link to comment Share on other sites More sharing options...
Brian r Posted March 22 Report Share Posted March 22 On 3/19/2026 at 11:46 PM, Wubster100 said: SlaveExists_ALM_Cfg It should be 726-65-01 xxx*-xxxx-xx 0 = absent 1 = present Thanks for the reply. He is what I have done so far and they still won't light.  1. Cut off the end of a 12 volt cigarette lighter plug to use as power and ground. Ran those two wires to the cupholder. I just did this to test, will get a permanent solution if I get this to work 2. installed a new pin in slot 13 of the bcm harness c2280G and ran wire to cupholder 3. changed bcm 726-65-1-01 to 0001-0100-0095 4. changed apim 7DO-01-02 to 000-D438-381E, I didn't change the 3 in the last series to a 2 because my cup holder is only ice blue  I don't understand what you mean by SlaveExists_ALM_Cfg  Is there anything I am missing because the light on the cupholder still won't come on? Quote Link to comment Share on other sites More sharing options...
Brian r Posted March 22 Report Share Posted March 22 On 3/19/2026 at 11:46 PM, Wubster100 said: SlaveExists_ALM_Cfg It should be 726-65-01 xxx*-xxxx-xx 0 = absent 1 = present I got it working. I also had to change 726-45-01 to xxx-x3xx-xxx. I ended up using power from the 12 volt outlet in the car. The cupholder lights come on when the headlights come on. However, they say on if you then turn the headlights off until you shut off the car. I also can't dim them or turn them off using the sync screen. Can you control your cupholder lights from the screen? 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted March 31 Author Report Share Posted March 31 On 3/22/2026 at 7:06 PM, Brian r said: Can you control your cupholder lights from the screen? Yes, I am able to. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted March 31 Author Report Share Posted March 31 Ambient Lighting The ambient lighting subsystem consists of the BCM, and the Light Emitting Diodes (LEDs) located within the floor console, front and rear door panels, instrument panel and front and rear footwell areas. The ambient lighting is operational when the ignition is in any state other than OFF (the exception is when it is used in conjunction with the illuminated entry/exit features), the headlamps are on and the outside ambient light level is low. The BCM provides the voltage to the ambient lighting system, while the touchscreen ( FDIM) is used to cycle through the different color variations or turn the ambient lighting feature on or off. A LIN circuit is routed from the BCM to all of the Light Emitting Diodes (LEDs). There are 3 Light Emitting Diodes (LEDs) (red, blue and green) housed within each LED assembly. By illuminating various color combinations, the Light Emitting Diodes (LEDs) are able to produce different colors of ambient light. The APIM uses software to monitor the user interface from the touchscreen. Based on the ambient lighting system selections made using the touchscreen, the APIM sends ambient light color request and ambient light intensity request messages over the communication network for color and brightness settings. The BCM retains the last color and brightness setting between uses. For 2021+ the factory option is single color Ice Blue. 1 Quote Link to comment Share on other sites More sharing options...
Brian r Posted April 24 Report Share Posted April 24 On 5/7/2025 at 5:16 PM, Wubster100 said: Welcome to the forum @Ron Ron!  The lights were powered by connecting to different power sources around such as the door modules and rear windows. The lights use very little electricity. A standard USB port will not work because it only provides 5 volts, while the light modules need 12v.  The cup holders are more intricate, connecting to the body control module and being controlled by the touch screen. Do you remember where you got power for the front 2 doors. I was able to use the window wire for the rears but all I can find in the front is a constant 12 volt wire that  powers the door.module  I need to find a acc wire so the lights go off with the car.  Did you use one of the small 20 gauge wires? Quote Link to comment Share on other sites More sharing options...
kyleberretta Posted Monday at 06:40 PM Report Share Posted Monday at 06:40 PM That looks really nice, and it looks like it's very similar to the kit I have, I was wondering because I have been trying to figure out how to do the ambient acrylic kit for my car how do you get the strip that's on your passenger side in in the doors wired to power or how did you route the power wire from the fuse box to the passenger side? 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted 19 hours ago Author Report Share Posted 19 hours ago On 6/22/2026 at 2:40 PM, kyleberretta said: how did you route the power wire from the fuse box to the passenger side? I got power from the door modules in the front, and in the back, power from the windows. Quote Link to comment Share on other sites More sharing options...
