fordedge2014limited Posted February 7, 2025 Report Share Posted February 7, 2025 My 2014 Edge Limited is clunking over bumps and when the wheel is fully turned. I've replaced the struts, knuckles/bearings, sway bar links, inner and outer tie rods, cv axles, lower ball joints, engine and transmission mounts. When I drove it it still clunked badly over bumps. Shook the vehicle and saw where the sway bar link was loose and knocking around. Took it to an alignment guy and he made sure my tires where aligned and my sway bar links where tight, as well as tightening some bolts on the struts, not sure exactly which ones 🤔 Now when i shake the vehicle no noise at all, sway bar links are good. But still clunks over bumps unless taken very slow, and clunks when the wheel is fully turned when driving I did read on another forum post that there is a nut to tighten in the wheel well for the struts ? First time doing suspension work, please help me lol 😆 😅 🙏 Quote Link to comment Share on other sites More sharing options...
31bullitt16 Posted February 13 Report Share Posted February 13 There’s only 6 attaching points for the struts. Have you checked the Inner tie rods, rack mounting bolts/bushings? Quote Link to comment Share on other sites More sharing options...
