Wubster100 Posted March 3 Report Share Posted March 3 (edited) 1 hour ago, Iroga said: Maybe the problem is with the camera itself? Should I try replacing it? Or will it not help? Before you replace the camera itself, you must verify the integrity of the wiring, connectors, and terminals. No short circuits, open circuits, poor connections, etc. Edited March 3 by Wubster100 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted March 3 Report Share Posted March 3 Have you made any AsBuilt modifications that may have caused this? Quote Link to comment Share on other sites More sharing options...
Iroga Posted March 3 Author Report Share Posted March 3 I will follow your recommendations. I have not made any changes. 1 Quote Link to comment Share on other sites More sharing options...
Iroga Posted March 4 Author Report Share Posted March 4 Did as recommended. Disconnected the connector. Rebooted the IMPA module. Enabled self-test. The result is in the photo. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted March 5 Report Share Posted March 5 There is definitely an issue with the IPMA or the wiring. Clearly the IPMA thinks that the heater circuit does not have any problems, but that is not true because the heater was disconnected from the IPMA. Quote Link to comment Share on other sites More sharing options...
Iroga Posted March 6 Author Report Share Posted March 6 (edited) 22 hours ago, Wubster100 said: There is definitely an issue with the IPMA or the wiring. Clearly the IPMA thinks that the heater circuit does not have any problems, but that is not true because the heater was disconnected from the IPMA. It's already warm and I won't be able to check the operation. I'll try to connect another camera later. I'll check the wiring from the camera, of course. If you disconnect the rain sensor, then Forscan sees that it's not there. Can updating the camera firmware help? Edited March 6 by Iroga Quote Link to comment Share on other sites More sharing options...
Iroga Posted Wednesday at 02:50 PM Author Report Share Posted Wednesday at 02:50 PM I can’t seem to fix the heating of the camera. 1 Quote Link to comment Share on other sites More sharing options...
Iroga Posted Wednesday at 03:22 PM Author Report Share Posted Wednesday at 03:22 PM (edited) Got it. It's an IMPA camera? Edited Wednesday at 03:53 PM by Iroga 1 Quote Link to comment Share on other sites More sharing options...
Iroga Posted Wednesday at 03:55 PM Author Report Share Posted Wednesday at 03:55 PM In section 151, figures 41 and 42, you can see the physical location of the connector for this C908 module. Can anyone help and post it here? 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted Wednesday at 09:55 PM Report Share Posted Wednesday at 09:55 PM When testing, what does the ambient air temperature value show in the live data? The heater may be commanded on if the ambient temperature is below 5°C (41°F). Quote Link to comment Share on other sites More sharing options...
Iroga Posted Thursday at 03:53 AM Author Report Share Posted Thursday at 03:53 AM 5 hours ago, Wubster100 said: When testing, what does the ambient air temperature value show in the live data? The heater may be commanded on if the ambient temperature is below 5°C (41°F). I realized that. It was -1°C. 1 Quote Link to comment Share on other sites More sharing options...
Iroga Posted Thursday at 03:55 AM Author Report Share Posted Thursday at 03:55 AM Maybe me should install a different camera for testing? Quote Link to comment Share on other sites More sharing options...
Iroga Posted 21 hours ago Author Report Share Posted 21 hours ago Replacing the IMPA did not help. Tell me, what if I connect this heating to the rear window or mirror heating? Quote Link to comment Share on other sites More sharing options...
Iroga Posted 20 hours ago Author Report Share Posted 20 hours ago Are there any 2019 Ford Edge rear defogger wiring diagrams? Quote Link to comment Share on other sites More sharing options...
