TSB 25-2283 - 2024-2025 Nautilus - Inbound Call Cannot Be Heard, Wireless Charger Icon Inaccurate, And/Or Auto Hold-Start-Stop/Defrost Button Indicators Inoperative
TSB 25-2157 HAS BEEN SUPERCEDED BY TSB 25-2283, WHICH IS POSTED IMMEDIATELY BELOW
TECHNICAL SERVICE BULLETIN
Inbound Call Cannot Be Heard And/Or Wireless Charger Icon Inaccurate
25-2157
17 April 2025
Model:
Ford
2025 Explorer
Lincoln
2024-2025 Nautilus
2025 Aviator
Markets: North America markets only
Issue: Some of the vehicles listed in the Model statement above may exhibit at least one of the following conditions:
• Inbound call cannot be heard
• Wireless charger icon inaccurate
This may be due to the APIM software.
Action: For vehicles that meet all of the criteria in the Issue and Model statements, follow the Service Procedure to reprogram the APIM.
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Service Part Warranty (SPW)/Service Part New Vehicle (SPNV)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/SPW/SPNV/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
Description Operation No. Time
2024-2025 Nautilus, 2025 Explorer/Aviator: Perform software update for GWM, TCU and APIM per service procedure. Includes time to clear codes. 252157A 1.9 Hrs.
Additional Time For Further Updates To GWM, TCU and APIM “Refer To Warranty & Policy Manual, Section 1.3 For Time Recording Requirements And Procedures For Actual Time. Ford Monitors Module Reprogramming Vehicle History Session Data To Compare Against Warranty Claiming Activity” (Can Be Claimed With Operation A) AP252157 Actual Time Up To 2.0 Hrs.
Repair/Claim Coding
Causal Part: 14H522
Condition Code: 04
Service Procedure
NOTE: The time required to complete this procedure varies depending on several factors including the number of module software updates required, available internet bandwidth, USB flash drive variability, and the potential that CAN flashing (software update via the DLC with FDRS) may be required. Connect to the internet with an ethernet cable, use a USB 3.2 Gen 2 or higher flash drive. When performing USB software updates, using high speed USB ports on the laptop is recommended for faster file transfer.
1. Start an FDRS session and navigate to Toolbox tab > Datalogger > body control module ( BCM) and select the BATT_SOC PID. Verify the PID reads 50% or higher.
NOTE: Connecting the battery charger negative clamp directly to the battery negative terminal might result in the SOC PID not immediately reflecting the improvement from charging.
(1). If SOC is less than 50%, charge the battery by attaching the battery charger's negative clamp to the engine or chassis ground and not the negative battery terminal. Refer to WSM, Section 414-01.
(2). If the battery is unable to achieve a 50% SOC, use the Rotunda GRX-3590 or DCA-8000 testers to verify if replacement is required.
• If the battery does not need to be replaced, disconnect the Rotunda charger and perform a BMS reset using the FDRS scan tool.
• If the battery is replaced, fully charge the new battery, disconnect the Rotunda charger and perform a BMS reset using the FDRS scan tool.
• Claim the battery testing and replacement outside of this article.
2. Reconnect the battery charger and set it to maintain a vehicle voltage of 12.6-13.6 volts. A low battery voltage or SOC while performing a software update to any module may result in a repeat "Restart Required" message in the vehicle's center display screen or a message on the FDRS saying "Part Number Validation Failed" or "DID Validation Failed".
3. Run the "Read The Configuration Data" app in FDRS, located in Toolbox > Multi- Module tab.
4. Navigate to the SW Updates tab. Is there a software update available for any of the following modules?
  • GWM
  • TCU
  • APIM
(1). Yes - proceed to Step 5.
(2). No - this article does not apply.
5. Prepare to update the software for the GWM, TCU, and APIM.
(1). A 64GB or larger USB flash drive is required for GWM, TCU, and APIM software updates. USB 3.2 Gen 2 or higher is recommended for faster file transfer on both the computer port and the USB drive.
(2). Make sure the USB flash drive being used is formatted correctly. To see the available drives, hold down the Windows icon keyboard key and press the E keyboard key. Right click on the USB flash drive and select Properties. If File System under the General tab is not exFAT, the drive must be formatted.
(3). To format the USB flash drive:
• Right click on the USB flash drive.
• Select Format, select exFAT for the File System.
• Select Default Allocation Size for the Allocation Unit Size.
(4). De-selecting Quick Format is not necessary and results in a lengthier operation.
6. Using the FDRS, begin module programming by selecting the "SW Updates" tab. Follow all on-screen instructions carefully.
7. When prompted, connect the USB flash drive to the FDRS.
8. When prompted by the FDRS, safely remove/eject the USB flash drive from the FDRS. Start the vehicle ( KOER) then connect the USB flash drive to the USB media hub to install the software into the module. When the USB software update begins, the center display screen displays a message stating "Do Not Remove USB". The update may take 10 minutes or longer to complete.
NOTE: It may take up to 5 minutes for the vehicle to recognize the USB flash drive with software update.
9. When the vehicle's center display screen prompts to restart the vehicle:
(1). Turn the vehicle OFF.
(2). Wait 10 minutes.
(3). Restart the vehicle (KOER). The update is still in process at this time.
10. Follow FDRS on-screen prompts to complete the update.
NOTE: It may take up to 5 minutes before "Update Successful" appears in the vehicle's center display screen. After 5 minutes if "Update Successful" pop-up is not shown on the center display screen, remove the USB flash drive and select YES on the FDRS prompt stating "Was The USB Update Successful" ( FDRS verifies if the module software update was successfully installed on the module).
11. Perform the software update for the GWM. Follow all update screens. If there is no GWM software update available, proceed to Step 12.
(1). If there is no screen prompt indicating that the software update is in progress:
• Perform the Digital Experience reset.
(2). Follow the center display screen prompts.
(3). Follow FDRS prompts to complete the GWM programming.
• Once the pop up stating "Update Successful" appears in the center display screen, select Close, remove the USB flash drive from the USB media hub, and select Yes on FDRS indicating the update installed successfully. This initiates the remaining automated configuration steps and reports the module software part numbers and application software levels to the Ford online database. Failure to follow this step results in an inaccurate database as well as omitted, improperly installed, or improperly configured applications (features) such as navigation (if equipped). It is normal for the module to reset during this step.
(4). Proceed to Step 12.
12. Perform the software update for the TCU. Follow all update screens. If there is no TCU software update available, proceed to Step 13.
(3). Follow FDRS prompts to complete the TCU programming.
(4). Proceed to Step 13.
13. Perform the software update for the APIM. Follow all update screens. If there is no APIM software update available, proceed to Step 14.
(3). Follow FDRS prompts to complete the APIM programming.
(4). Proceed to Step 14.
14. Format the USB drive.
  • De-selecting Quick Format is not necessary and results in a lengthier operation.
NOTE: The USB drive must be formatted immediately after the APIM software update (prior to updating any other module) or the subsequent updates may fail.
15. Refresh the FDRS files.
(1). Click on envelope icon.
(2). Select Refresh FDRS Files (this will close FDRS when completed).
(3). Launch FDRS.
(4). Start new FDRS session.
16. Are there any updates available for the GWM, TCU, and/or APIM?
NOTE: The option to update a module may not be available until other module(s) are updated to a certain level. The network test is a confirmation that all modules are at the latest available software. Some repairs may require multiple network tests to reveal all module dependent software.
(1). Yes - proceed to Step 11.
(2). No - repair is complete.
© 2025 Ford Motor Company
All rights reserved.
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supersede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Edited by Haz
  • Like 3
  • 2 months later...
Posted (edited)
Placing your device cursor over underlined acronyms may yield popup full-words descriptions of the acronyms.
Inbound Call Cannot Be Heard, Wireless Charger Icon Inaccurate, And/Or Auto Hold/Auto Start-Stop/Defrost Button LED Indicators Inoperative
25-2283
25 June 2025
This bulletin supersedes 25-2157. Reason for update: update the customer symptom.
Model:
Ford
2025 Explorer
Lincoln
2024-2025 Nautilus
2025 Aviator
Markets: North American markets only
• Auto hold, auto start-stop, and/or defrost button LED indicators inoperative
Labor Times
2024-2025 Nautilus, 2025 Explorer/Aviator: Perform software update for GWM, TCU and APIM per service procedure. Includes time to clear codes. 252283A 1.9 Hrs.
Additional Time For Further Updates To GWM, TCU and APIM “Refer To Warranty & Policy Manual, Section 1.3 For Time Recording Requirements And Procedures For Actual Time. Ford Monitors Module Reprogramming Vehicle History Session Data To Compare Against Warranty Claiming Activity” (Can Be Claimed With Operation A) AP252283B Actual Time Up To 2.0 Hrs.
Repair/Claim Coding
Causal Part: 14H522
Condition Code: 04
Service Procedure
1. Start an FDRS session and navigate to Toolbox tab > Datalogger > body control module (BCM) and select the BATT_SOC PID. Verify the PID reads 50% or higher.
3. Run the "Read The Configuration Data" app in FDRS, located in Toolbox > Multi-Module tab.
  • GWM
  • TCU
  • APIM
8. When prompted by the USB, safely remove/eject the USB flash drive from the FDRS. Start the vehicle ( KOER) then connect the USB flash drive to the USB media hub to install the software into the module. When the USB software update begins, the center display screen displays a message stating "Do Not Remove USB". The update may take 10 minutes or longer to complete.
(1). Select Format, select exFAT for the File System.
(2). Select Default Allocation Size for the Allocation Unit Size.
(3). De-selecting Quick Format is not necessary and results in a lengthier operation.
(3). Launch FDRS
TSB 25-2283 - Inbound Call Cannot Be Heard, Wireless Charger Icon Inaccurate, And-Or Auto Hold-Auto Start-Stop-Defrost Button LED Indicators Inoperative.pdf
Edited by Haz
  • Haz changed the title to TSB 25-2283 - 2024-2025 Nautilus - Inbound Call Cannot Be Heard, Wireless Charger Icon Inaccurate, And/Or Auto Hold-Start-Stop/Defrost Button Indicators Inoperative
