99stang Posted May 12, 2025 Report Share Posted May 12, 2025 I have a 2018 Ford Edge Titanium with Sony audio. The AM and FM radio reception went away while we were listening to it. It plays music from my phone just fine but in radio mode, all I get is static. If I press the seek button, it just keeps scanning and never picks anything up. I tried a "soft reset" by holding the power button and right seek button simultaneously. That worked but the signal disappeared shortly after. I made sure the firmware was updated via wifi and I disconnected the battery for 10 minutes and reconnected it. I was hoping someone could offer some helpful advice. I feel that my only hope for repair is at a Ford repair facility but I also feel that it is probably going to be very expensive. I feel some would suggest replacing the head unit with an aftermarket replacement but worry that it will be glitchy and won't work as well as this one did before it crapped out. Any help is greatly appreciated. Thank you. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 16, 2025 Report Share Posted May 16, 2025 Next time it happens try using the steering wheel controls. If the radio still doesn't work, or the radio comes back, it's probably in the APIM (sync module). If the steering wheel controls do work, it's probably either in the ACU (the radio) or the electric antenna. I'd suspect corrosion where the antenna plugs in (but thats just a guess.) 1 Quote Link to comment Share on other sites More sharing options...
ford07 Posted June 2, 2025 Report Share Posted June 2, 2025 Checking the radio antenna is often the main cause when the radio receives poorly or not at all, while the Bluetooth/digital functions work perfectly. Quote Link to comment Share on other sites More sharing options...
