Dash Cam Power Adapter Through The Rain Sensor
Jetboy47
The module in the link below connects to a rain sensor three pin connector but I need to know if my 2023 ST has this three pin connector. They also have modules that are 7 pin, 16 pin as well as universal one where you find the 12v voltage from. Can anyone confirm that my vehicle has this three pin connector, or if not what type of connector is the rain sensor connected to.
https://fitdvr.com/collections/ford/products/dash-cam-power-adapter-3-pin-for-ford-and-lincoln-connects-to-rain-sensor-d3-042
Edited by Jetboy47
You should pop off the cover like it says and check.
My 2019 SEL has 5 pin wiring to the rear view mirror, I was able to find the male and female connectors and pins to make my own harness to get switched 12v from the rear view mirror. I wasn't willing to spend $42 on a Dongar adapter, or $150 like the one you posted.
8 hours ago, Jetboy47 said:
Very nice. The one I posted was $37 not $150. Is it easy to pop off the cover?
You might want to ask if anyone can post the connector pinout and wire colors for your 2023 for the rear view mirror and the rain sensor.
It pulls straight away from the windshield, there are 4 clips that hold it in place:
