Bunky Posted June 12 Report Share Posted June 12 (edited) I have never used premium gas in my vehicles because I saw no real need. I tried it in my 24 Nautilus and did not see much difference. I do not tow or drive under heavy load in hot weather. BTW, I do use premium fuel in my outdoor power equipment since ethanol free is only available in premium grade. Some have continued to promote using it and saw a new argument that goes like this. The 2L in my Nautilus has 2 injectors (one rail, one direct) per cylinder. One downside to direct injection is supposed to be more valve build up since the spray goes over the valve.. As told, at low power situations, the engine uses the rail injectors and under higher load it switches to direct. The claim is that premium fuel allows the engine to use the upper rail injectors longer before switching to the direct injectors. Therefore, valve buildup is reduced. Of course, no claims on how much. Can someone confirm how the rail and direct injectors actually work? Edited June 12 by Bunky Quote Link to comment Share on other sites More sharing options...
dabangsta Posted June 12 Report Share Posted June 12 It is interesting that the 2.0 FHEV is both port and DI, I didn't know that. Some vehicles with the 2.3 got dual injection in 2024. (I know other engines got it earlier) Port Injection is more for when it is idling and moderate throttle position (it helps with misfires at low speeds compared to DI), and under demand or high throttle position it uses the Direct Injection. 1 Quote Link to comment Share on other sites More sharing options...
