JMB Posted June 14, 2025 Report Share Posted June 14, 2025 Good morning everyone. I am do the rear brakes on a 2017 Sport. I was looking for the torque value for the caliper bracket and the caliper slide pin. I purchased a down loadable Ford repair manual 2015 to 2024 manual from eBay. Manual is date 2015. That has the caliper bracket at 99 ft-lb and the slide pins at 21 ft-lb. I thought to myself 99 ft-lb seemed high. I started to look around on line which seems to be hard to find exactly. Goggle has it at 66 ft-lb. Also a YouTube video on a 2018 Sport has it at 41 ft-lb. Caliper side pin I have found at 21 ft-lb and 19 ft-lb which is not to far off. Wheel torque is right at 162 ft-lb which is correct. Quote Link to comment Share on other sites More sharing options...
Haz Posted June 14, 2025 Report Share Posted June 14, 2025 (edited) Welcome to the Forum @JMB! From the 2017 Edge Workshop Manual... Front Brake Caliper Flow Bolt torque: 18 lb.ft (25 Nm) Front Brake Caliper Guide Pin torque: 41 lb.ft (55 Nm) Front Brake Caliper Anchor Plate torque: 111 lb.ft (150 Nm) Front Brake Disc Shield torque: 106 lb.in (12 Nm) Rear Brake Caliper Flow Bolt torque: 18 lb.ft (25 Nm) Rear Brake Caliper Guide Pin torque: 21 lb.ft (28 Nm) Rear Brake Caliper Anchor Plate torque: 66 lb.ft (90 Nm) Parking Brake Actuator Motor torque: 71 lb.in (8 Nm) Rear Brake Disc Shield torque: 106 lb.in (12 Nm) Wheel/Tire torque: 162 lb.ft (220 Nm) WARNING: Retighten wheel nuts within 160 km (100 mi) after a wheel is reinstalled. Wheels can loosen after initial tightening. Failure to follow this instruction may result in serious injury to vehicle occupant(s). NOTICE: Failure to tighten the wheel nuts in a star/cross pattern can result in high brake disc runout, which accelerates the development of brake roughness, shudder and vibration. NOTE: The wheel nut torque specification is for clean, dry wheel stud and wheel nut threads. NOTE: Final tightening to be performed with vehicle resting on tires. Good luck! Edited June 14, 2025 by Haz 2 Quote Link to comment Share on other sites More sharing options...
JMB Posted June 29, 2025 Author Report Share Posted June 29, 2025 My apologies for taking so long to respond back to you. I knew something did not see right with torque values. I guess that is what I get for buying a manual off eBay. Should have come here first. I was able to get the brakes done. I was amazed how easy it was to push the pistons back into the caliper. I do not need to spin them back in. I bought a brake tool compressor kit believing I need to screw them in. Will also use the info here to do the front. Thank you very much Haz for posting this for me. 1 1 Quote Link to comment Share on other sites More sharing options...
