ylwpaul Posted 15 hours ago Report Share Posted 15 hours ago (edited) Any ideas out there for a parasitic draw on a 2011 Ford Edge? The draw is 2.2A every minute and a half or so. When the drain stops the quiescent draw is 16mA which seems reasonable. It looks like the BCM might be involved as the positive cable that feeds the BCM registers the 2.2A with a clamp current meter. Any ideas? Edited 15 hours ago by ylwpaul Quote Link to comment Share on other sites More sharing options...
Haz Posted 4 hours ago Report Share Posted 4 hours ago Battery Drain analysis procedures from the 2011 and 2015 Edge Workshop Manuals and fuse-circuit information are attached below as PDF documents. Click here to view Ford parasitic draw test (Link to extremely thorough, step-by-step online video, which contains no audio commentary), referenced in 2015 document. Good luck! Battery Drain Test - General Procedures - 2011 Edge Workshop Manual.pdf Battery Junction Box Diagram - 2011 Edge.pdf Battery Junction Box - Fuse-Circuit Listing - 2011 Edge.pdf Body Control Module (BCM) aka Smart Junction Box (SJB) Diagram - 2011 Edge.pdf Body Control Module (BCM) aka Smart Junction Box (SJB) - Fuse-Circuit Listing - 2011 Edge.pdf Battery Drain Check - General Procedures - 2015 Edge Workshop Manual.pdf Quote Link to comment Share on other sites More sharing options...
