markfm Posted August 15, 2025 Report Share Posted August 15, 2025 Exterior lighting failure can reduce visibility for the driver and other road users, increasing the risk of a crash. Light Emitting Diode (LED) Driver Module (LDM). On affected vehicles, a headlamp assembly’s LDM may fail. A failed LDM will result in that headlamp assembly’s high beam, low beam, position lamp, daytime running lamp and turn signal operation becoming inoperative. For Nautilus vehicles only, a failed headlamp assembly’s LDM also may result in the same-side rear tail lamp, rear turn signal, and rear position lamp becoming inoperative. Inoperative lighting features may result in non-compliance with FMVSS 108. Vehicles Affected (Production Dates) Nautilus - Mar 09, 2025 - Jul 24, 2025 Mustang - Mar 04, 2025 - Jul 18, 2025 Mustang Mach E - May 19, 2025 - Jul 15, 2025 1,539 Nautilus vehicles are affected. 808 Mach-E vehicles are affected 19,418 Mustang vehicles are affected Planned Dealer Notification Date: Aug 11, 2025 - Aug 11, 2025 Planned Interim Owner Notification Date: Aug 25, 2025 - Aug 29, 2025 Planned Remedy Owner Notification Date: Oct 01, 2025 - Dec 31, 2025 Date when VIN will be searchable: Aug 11, 2025 Source: https://static.nhtsa.gov/odi/rcl/2025/RCLRPT-25V519-1620.pdf (above material is extracted from the reference) 1 Quote Link to comment Share on other sites More sharing options...
Bunky Posted August 15, 2025 Report Share Posted August 15, 2025 It is Interesting that the break in dates are so close together for the Nautilus and Mustang given they are built so far apart. Quote Link to comment Share on other sites More sharing options...
