Puddle light went out
First thing to try in troubleshooting is to switch the lamp assembly in the passengers side to the drivers side, (and drivers side to passengers side.)
If the passengers assembly no longer works in the drivers side, you have a wiring problem in the drivers mirror or where the wiring passes from the body into the door. (Especially true if the one that failed in the drivers door now works in the pass door.)
If the passengers assy continues to work in the drivers side, you have a defective replacement (and OEM) assembly.
Edited by enigma-2
