Help. Gasoline Fumes, Smell 2011 Edge Limited 3.5
Tucson Bob
Every gas fill-up there is a very strong Gas smell near the rear and drivers side near filler tube.  Smell pretty much stops when the gas level get down 3/4 of a tank. Shop says the gas tank had leak so we replaced fuel tank and fuel pump for $2500.  This did not solve gas smell problem. We replaced the Purge Valve,  and entire EVAP system.  Still has gas smell. My mechanic can't figure it out. They did smoke test and could not locate any leaks.
Has anybody experienced this?  Any potential solutions?  Only thing left we thought might be filler tube?
Edited by Tucson Bob
  • Tucson Bob changed the title to Help. Gasoline Fumes, Smell 2011 Edge Limited 3.5
