trtaylor Posted Friday at 02:00 PM Report Share Posted Friday at 02:00 PM I have a 2017 Ford Edge Titanium that produces a loud rattle from the right rear when driving over a significant rough area on the road. Or something that imparts a sudden up/down movement to the rear suspension. For example, driving over a speed bump slightly faster than I should. It is not a persistent rattle. It is quite loud when it occurs. Otherwise the vehicle is quiet. The first thing I thought of was something not secured in the spare tire storage area. But that wasn't it. Everything is secured in that area. I know it is a silly description, but it actually sounds like there is a box full of dinner dishes in the back. They would not rattle just driving down the road. But they would rattle quite loudly if going over a speed bump. Are there known issues with any of the rear suspension components? The next time it goes in for an oil change, I will ask the service tech to put it on a lift to see if something is loose or broken. Is there a chance it is coming from the rear liftgate? Like most issues, it has probably occurred in others. So I thought I'd ask here. Thanks. Tim Quote Link to comment Share on other sites More sharing options...
NIS0003 Posted 22 hours ago Report Share Posted 22 hours ago More than than likely is stabilizer links causing the noise. These in the front and back of the vehicle. I have changed mine several times over the years. My Edge is a 2013 and i have replaced front and back about 3 times. 1 Quote Link to comment Share on other sites More sharing options...
trtaylor Posted 2 hours ago Author Report Share Posted 2 hours ago 20 hours ago, NIS0003 said: More than than likely is stabilizer links causing the noise. These in the front and back of the vehicle. I have changed mine several times over the years. My Edge is a 2013 and i have replaced front and back about 3 times. Thank you. I will have these looked at. Quote Link to comment Share on other sites More sharing options...
