Fun question (with serious consequences)
enigma-2
● You check your tire pressure.
● You check your transmission fluid level.
● You check your coolant level.
● You check your power steering fluid level.
● You check your brake fluid level.
● You check your oil level.
● You check your engine air filter.
● You check your cabin filter.
● You check your seat filter.
● You check your exterior. lights to verify everything's working.
...... What are you forgetting?
....... What's the one thing you should be checking but haven't since .... ????
•• Tire pressure of the spare tire, hidden away in the trunk.
Edited by enigma-2
