USB CD Player For 2024 Ford Edge SYNC4
Ronno6
Is there a USB connectable CD player that will work in my 2024 Edge w/SYNC 4 ??
We like to listen to audio books when traveling.
I have tried ripping to USB flashdrives, and have had some success.
Getting all MP3 tags in order is very tedious and time consuming.
But, i find playback to be tedious and extremely distracting.
i have loaded on MP3 players and that plays OK, but, again, distracting.
And the only usable  way to play the MP3 player thru the stereo is by using an FM modulator to transmit to the Edge radio.
Plugging in a suitable CD player would make things much easier............or, even an in-dash unit..
8 hours ago, Ronno6 said:
I am  not sure that any Bluetooth device will work with SYNC 4
Seems to me that somewhere I informed that only devices compatible with Apple Carplay will connect...
You are able to connect using Bluetooth, Apple CarPlay, and Android Auto.
Do BT  CD players have the "Pairing" function?
Do they need to have one?
The CD player would need the ability to connect to and output to a Bluetooth speaker. The car acts as a Bluetooth speaker.
Well, put me in the oven and call me a biscuit......A CD player that works via USB !!
Even controllable via steering wheel controls..........
Problem solved...except....where to mount it.
Looks like the flat tray above the infotainment screen........I just hope it won't overheat in the sun....
Anyone have a recommendation?
Edited by Ronno6
