HID's installed (DDMtunign) on 2011
Finally got around to installing them yesterday. All was rather straight forward. Only issue with the kid I had was mounting the ballasts... I finally got them both mounted with double sided tape and I will keep an eye on them to make sure they stay stuck.
The only other issue I had was the drivers side headlight bulb area is VERY tight so if you have big hands good luck! I think I spend a solid hour working the bulb out and putting the new one in.... very painful.
For the 2011 there are little caps that cover over where the bulb was, did you just leave them off? I have yet to put them back on but with the wire added there they wont go back on anyway.
Here is the details on what I ordered
HID-Harness $12.50
DDM HID Kit, 55W, 9006, 5000K (Kit / Package)
Bulb Color: 5000K
Bulb Type: 9006/HB4
Wattage: 55 Watt (+$10.00) - 50.00
Edited by SpectorV
  • 4 weeks later...
