Clarification on 10-2-09
Hello, new guy with a quick question over the wheel bearing TSB.
I know these threads may be a little played out, but I searched around, and didn't find what I was looking for. I have a 2008 AWD, and I'm about to replace the right rear bearing/hub assembly. I want to go ahead and replace the parts to comply with the TSB, and it seems my local dealership can't decide what all this involves. I'm doing the repairs myself, and I'm about to order parts, and I need to know if I'm supposed to replace the actual trailing arm, or just the bearing/knuckle assembly. Some of the employees read it as the trailing arm knuckle assembly, and some read it as the trailing arm AND knuckle assembly. Can I get some verification on what it is? Do I replace the actual trailing arm?
One other question, is a hub assembly puller the only "specialty tool" that I need?
Thanks in advance
