Custom Search
2011 Ford Edge 200 Series Remote Start DIY (BB5Z-19G364-C)
  • Please log in to reply
50 replies to this topic
#1 j3st3r
j3st3r
    New Edge Member
  • Edge Member
  • 20 posts
Posted 30 October 2011 - 08:11 PM
Thought this might be a good DIY to have.
**First working on your own vehicle you so at your own risk**
**Second this is the way I chose to do it, and is purely for guidance/help, I do not work for Ford, nor am I a Ford Technician**
Tools Needed:
T50 Torx Bit
Body Clip tool, or flat blade screw driver, or needle nose pliers
Diagonal Nose Wire Cutter Pliers (dykes)
Optional Tools:
Extra Wire Ties
10mm socket
Electrical Tape
200 Series Kit (Part #: BB5Z-19G364-C)
Whats Included in the Kit
1) Open the rear hatch and remove the center trim piece(no tools are required just, raise the hooks, and a good pull will do)
2) Raise the rear cargo/spare tire cover and remove
3) Remove the left rear plastic cargo/storage tray
4) Using body clip tool/flat blade screw driver/needle nose pliers remove the 2 plastic clips on the floor from the left rear side panel(these suck...so be patient)
Also be sure to unscrew and remove the top left rear cargo anchor
5) Open the left rear door and remove the small plastic cover in the door way(no tools required, simply a good pull will do)
6) Using a T50 Torx bit, remove the left rear seat belt anchor
7) You can then begin to separate the left rear panel from the vehicle(DO NOT pull this all the way off yet, since there are wires attached)
**NOTE when you separate the rear section of the left rear panel from the vehicle, be careful when pulling away the black rubber molding as Ford uses a tan grease/sealant on this, and it is hard to get off of things)
8) With the panel leaned over unplug all the connections that are attached to the left rear panel
Edited by j3st3r, 05 August 2016 - 11:46 PM.
  • 6772owner likes this
#2 Jasgal
Jasgal
    New Edge Member
  • Edge Member
  • 2 posts
Posted 30 October 2011 - 08:22 PM
Then what?
#3 j3st3r
j3st3r
    New Edge Member
  • Edge Member
  • 20 posts
Posted 30 October 2011 - 08:28 PM
Since you are only allowed to post so many images at a time I had to make multiple posts....
9) Once you have all of the wires removed, remove the 2 white plastic body clips from the panel
10) Remove the left rear panel
The first item to go in will be the antenna module
This is where the antenna module will mount
11)Plug in the grey plugged antenna wire(it is the one with several body clips attached to it)
12) Using the supplied white wire ties attach the antenna to the vehicle
13) Its now time to mount the antenna
Plug the black 5-wire harness into the antenna
14) Route 5-wire antenna harness through the plastic C-Pillar cover
15) Remove the protective film from the double sided tape on the back of the antenna and attach to rear window(You may want to clean the window with alcohol before sticking antenna to window)
Edited by j3st3r, 05 August 2016 - 11:58 PM.
#4 j3st3r
j3st3r
    New Edge Member
  • Edge Member
  • 20 posts
Posted 30 October 2011 - 08:52 PM
Its now time to mount the remote start module
This is where the module will mount
16) Remove the protective film from the velcro on the remote start module and attach to vehicle fender well
17) Plug in the 5-wire antenna wire to the remote start module
18) Using extra wire ties clean up the excess wiring
19) Now attach the main harness to the remote start module(The plugs are poka-yoked so only one will fit the plug on the remote start unit)
Now we will run the led, and the valet switch to the front of the vehicle
20) Open the drivers side door and remove the plastic trim piece from the door way(no tools required, and good pull will do)
While your here go ahead and pop open the plastic covers(we will be running the wires along side the factory runs)
20) Remove the B-pillar plastic cover(no tools required, a good pull will do)
20b **This step is optional, but it makes things eaiser**
Where you removed the plastic cover in step 5 there is a black plastic cover that houses the wires. If you lift up slightly on the carpet there you will notice 2 10mm nuts. Remove these, but do not remove the plastic piece. We will leave this loose so we can route our led, and valet switch through it
Edited by j3st3r, 06 August 2016 - 12:07 AM.
#5 j3st3r
j3st3r
    New Edge Member
  • Edge Member
  • 20 posts
Posted 30 October 2011 - 09:10 PM
21) Begin routing/securing the led, and valet switch to the front of the vehicle along the factory wiring harness, using electrical tape, or wire ties
Route the wires through the black plastic piece from Optional Step 20b
Continue following factory harness past the B-Pillar
Route the 2 wires through the drivers side factory loom in the door way
[imghttps://photos.smugm.../edge_rs077.jpg[/IMG]
Once you have these 2 wires up front near the fuse panel under the dash you can then close the plastic doors that cover the wires in the door way
22) Go ahead and then tighten the 2 10mm screws, if you used the Optional 20b step
23) Re-attach the B-Pillar cover
24) Reinstall the plastic trim piece in on the drivers side door well
25) Next we will install the shock sensor, remove the protective film from the double sided tape and attach shock sensor to vehicle
26) Plug the shock sensor into the main remote starter wiring harness
27) Plug the square vehicle wiring harness plug into the remote starter wiring harness
Its now time to reinstall the left rear cover panel
Edited by j3st3r, 09 August 2016 - 10:33 PM.
#6 j3st3r
j3st3r
    New Edge Member
  • Edge Member
  • 20 posts
Posted 30 October 2011 - 09:39 PM
28) Set the left rear panel back in the vehicle so that you can reattach all of the wiring to it
Attach the grey plugged harness for the light
29 Attach the grey plugged harness from the remote start antenna module, and the black & white square plugged harness from the remote start module to the panel
30) Tidy up all your wiring using electrical tape or wire ties
***Its worth noting here that the multiple body clips on the antenna wire harness are not used or attached to anything on the 2011 Edge ***
31) If your vehicle is equipped also re-attach the wire harness for the rear seat fold down switches and the 12v outlet
32) Re-install the left rear cover panel
Make sure you reinstall the 2 plastic body clips in the panel to the floor
33) Reattach the cargo net anchor
34) Using T50 Torx bit reattach seat belt anchor
35) Place left rear cargo/storage tray back into place
Edited by j3st3r, 09 August 2016 - 10:44 PM.
#7 tenstepn
tenstepn
    New Edge Member
  • Edge Member
  • 84 posts
Posted 30 October 2011 - 09:50 PM
OUTSTANDING GUIDE JESTER! I really appreciate the time and effort you put into this - I will give it a shot this week or next! So any thoughts on the system thus far??
#8 tenstepn
tenstepn
    New Edge Member
  • Edge Member
  • 84 posts
Posted 30 October 2011 - 09:51 PM
Oh and one more thing! Where did you buy from and what was the price?
#9 j3st3r
j3st3r
    New Edge Member
  • Edge Member
  • 20 posts
Posted 30 October 2011 - 09:54 PM
36) Re-attach center trim piece
37) Put spare tire cover back in place(if you removed it)
38) Re-attach the floor trim piece you removed in step 5
39) Put the cargo cover back into place
At this point everything is buttoned up.....except for where you want to mount your LED and Valet switch, right now they should be sticking out of your fuse box cover. I will let you decide on where you want to mount these to best suite your personal preference
The other thing that I did not put in the guide yet is the hood pin switch. This is required for the installation(Part # BT4Z-19G366-A)...I did not put it in this DIY yet because when I ordered the remote start I forgot to order it...:-( The part is ordered and will be in this week, so as soon as it is in, I will include it in the DIY. The hood pin switch is VERY easy to install, should not take more than 20 seconds.
Once everything is installed you will need to go to your dealer and have the unit activated via IDS. From what I have read the price is varying from dealer to dealer, our dealer here said it would be $79 to do. Again this will be done this week and I will post the results/process/experience as well as a video of it in action.
I hope this has helped, I know in watching the video(that video was from an F-150), that was posted on other thread/forums it would have you believe this install takes 30 minutes...while it might be possible to do it in that short of time, in my opinion to do it right it will take you a bit longer. While the install is not hard at all on the Edge, there are just a few more steps you have to go through.
Edited by j3st3r, 09 August 2016 - 10:47 PM.
#10 j3st3r
j3st3r
    New Edge Member
  • Edge Member
  • 20 posts
Posted 30 October 2011 - 10:12 PM
I got mine from Josh at Tasco Automotive Group, I am not sure if he wants the price posted so I will just give you his email address: jlaliberte@tasca.com
The original email I sent to him read
"....Hello, I have a 2011 Ford Edge and would like a price on the BB5Z-19G364-C remote start kit. Thanks!...."
I will say though that its was under $280!!
Edited by j3st3r, 30 October 2011 - 10:13 PM.
#11 wlepse
wlepse
    Ford Edge Enthusiast
  • Edge Member
  • 1,252 posts
Posted 31 October 2011 - 08:18 AM
Thanks for the write up...going to go through the steps and digest it. Need to do this too especially after the freak October snow storm we got the wife is applying more pressure.
  • fledgex likes this
#12 wlepse
wlepse
  • Edge Member
  • 1,252 posts
Posted 31 October 2011 - 09:20 AM
OK...I might have missed it but where do you connect the first antenna (the one that has body clips attached to wire)? I think this gets plugged into the TPMS box but not 100% sure. And what is the purpose of the second antenna?
When you get everything initialized let me know how the security system works. I had a dealer installed shock sensor on another car that was worthless. Initially it was set to be so sensitive it went off with heavy wind, they adjusted it but then it wouldn't go off even if I rocked the car by pulling the bike rack. If the system works well I would get the 200 series otherwise I may opt for the same system without the alarm. By the way I was told by an online retailer that you can purchase 9G1Z-15K601-A-F509 if you need another remote.
#13 j3st3r
j3st3r
    New Edge Member
  • Edge Member
  • 20 posts
Posted 31 October 2011 - 12:00 PM
Step 29
#14 wlepse
wlepse
  • Edge Member
  • 1,252 posts
Posted 31 October 2011 - 12:32 PM
Got it thanks! Again please update with a review of the system.
#15 wlepse
wlepse
  • Edge Member
  • 1,252 posts
Posted 02 November 2011 - 11:36 AM
Wow, the dealer by my office is completely off their rocker. They quoted me $156 to program the BCM and said there were no guarantees. Well I guess I know where I won't be going. The salesman was going to quote the whole system installed but based on their initialization price I am sure they are going to be too expensive. Still can't believe they want to charge that much, that gets me half way to owning my own hardware/software to do it myself. If I thought there were more people interested in my area I would buy the software and install these on the side to pay for the software. Oh well, got to call other dealers now.
#16 j3st3r
j3st3r
    New Edge Member
  • Edge Member
  • 20 posts
Posted 12 November 2011 - 01:24 PM
Ok got everything done today so here is the rest
Hood Pin Installation
40) Open your hood and you will see the place where the hood pin will install too
41) The plug for the hood pin switch is just under the hood pin switch mounting point, unplug this from the factory plastic piece
42) The hood pin switch only goes in one way so push it into the mounting hole until it clips in
43) Plug the plug you unplugged in step 41 into the bottom of the hood pin switch
Installation is now complete!!!
You will then need to go to your local dealer and have the remote start activated with IDS. I have heard and seen a lot of different prices for this....HOWEVER it took my dealer all of 30 minutes to do and was $45 for labor. If your dealer is gouging you or charging something else I would either report them to Ford, or find another dealer
Here is how the remote functions
...and here are the new Remote Start MyTouch Menus
Edited by j3st3r, 06 August 2016 - 12:16 AM.
#17 wlepse
wlepse
  • Edge Member
  • 1,252 posts
Posted 12 November 2011 - 02:41 PM
Thanks for the update....unfortunately my normal dealer wanted 160 buck and I am yet to find anyone under 99. Now I am just waiting to hear a price from them to do the whole job.
#18 outdoorsmunn
outdoorsmunn
    New Edge Member
  • Edge Member
  • 8 posts
  • Region:U.S. Northern Plains
Posted 29 December 2012 - 05:54 PM
Thanks for taking the time to do this write up, I am going to use it to put my remote start in. I noticed that your menu doesn't show the options for heated seats. Does your car not have heated seats or is it not available with these add-on remote starts? Thanks
  • sajid.ali likes this
#19 ranair911
ranair911
    New Edge Member
  • Edge Member
  • 4 posts
Posted 16 March 2013 - 10:42 PM
Did this vehicle already have the push button start feature.
#20 rsucre
rsucre
    New Edge Member
  • Edge Member
  • 35 posts
  • Region:Central America
Posted 25 March 2013 - 06:03 PM
The only way to activate this is using Ford VCM IDS?  My local dealer (I'm in Central America) wants to charge way too much (close to the price of the module itself) for activation.  Are there any alternative ways?  I even thought about buying a used or Chinese (probably clone) VCM IDS kit on eBay.  Do you think that car diagnostic shops could have the VCM IDS?
Edited by rsucre, 25 March 2013 - 06:11 PM.
