                Posts44
                Days Won1
Everything posted by GatorCat
	Great info! I'll bring it in to the dealer when the air runs down. At least it's a known problem and even if that's not the direct cause at least they should be able to check it out under warranty. Thanks!
	Having same problem on my 2011 sport with the Pirelli's. Front driver tire has a slow leak - takes 3-4 weeks to go from about 38 to 26 or so to trip the low pressure light. I haven't brought it in yet, but only have 15K miles on these tires so i'm a little concerned i'll have to pony up for some new tires at 250/each. Shame the reseating didn't work for you - i'll have to take mine in and see what they can do if anything. Wonder if anyone else has had success with fixing the issue...
	  Sync my ride MFT upgrade avaliable?GatorCat replied to mv-clear's topic in Audio, Backup, Navigation & SYNC Upgrade went smoothly from 2.4 to 2.11. I was so happy to do this at home - i was actually putting off an oil change to schedule that and the MFT upgrade together. Took me about 40 minutes with no adverse affects so far. Improvements from 2.4 to 2.11 include: bigger fonts, fixed Sirius channels with voice, snappier response (still not Apple-fast but much better than before), better USB integration with iPhone (fixed issues with building index and album art), faster on/off of backup camera. Hopefully with the at-home updates we can now get more frequent, incremental updates. I think we may be mostly happy once we get to v3.0! One note I thought was interesting - on the Mac it requires Google Chrome for browser integration. No other browser (including Firefox) is supported. Guess MS isn't running the show on these!
	I'm having similar experiences after upgrade to 2.4 about a week and a half ago. I had typical issues previously including inconsistent brightness of main screen, volume levels out of whack, had nav fault several times that took several restart cycles to resolve, etc. After going to 2.4, i still have inconsistent brightness of main screen (where it stays day bright on first startup at night sometimes) and had 1 major nav fault which wouldn't resolve until overnight. Last night our seat heaters wouldn't work after startup. Tried for about 5 minutes when suddenly screen goes black and does full restart, sync maintenance screen. After that it worked fine and was much faster for responses. My prior car was a G35 and every 3-6 months the whole nav/radio/environ system would freeze up in the morning and take about 15 minutes for complete reboot, but then it would work flawlessly until the next reboot. I can deal with occasional reboots but all this uncertainty with various functionality is really disturbing. I had higher hopes for the 2.4 update.
	I don't agree...this doesn't seem like an overreaction, since Ford is specifically stating that replacing APIM is not advised. I haven't seen anyone else with this dramatic of a problem, but if you really start to add up these various issues, there appears to be a class action lawsuit brewing. Slow response, lack of BT audio is problematic but forgivable. Malfunctioning speedometers that cannot be fixed is a major safety concern. When was the last time anyone here had a new car that had a malfunctioning speedometer that couldn't be fixed? Look at all the class action lawsuits regarding Apple and the quality of their materials (excessive scratching on iPods, easy breaking glass on iPhone). This is very troubling and is something we all need to stay abreast of.
	Yikes. This sounds like a hardware problem. When you had the 2.4 update done, did they replace your APIM module or just do the software? I'm starting to think that there are two sets of issues - one is a software item with all the regular bugs we see. The second is a hardware problem which causes those catastrophic failures. I think my hardware is good but have some problems with the software. I'm getting the 2.4 update tomorrow so we'll see. It is certainly plausible that a person could have a software problem then coincidentally end up with a hardware failure that would have happened regardless of the software.
	Yep. Have the problem too. Something with Safari mobile and this board software. I have had success with Atomic Web browser. Works better in general. Give that one a try and see if it helps. It does tabbed browsing. Overall the software for this board isn't well optimized for touch computing. I usually go to my laptop when I want to see what's up here.
	My '11 Sport has nav and I think that the map database is at least 1 year old, possibly 2. The POI data is quite a bit out of date and there are major roads that are more than a year old that aren't on the database at all. Have had missing data in Orlando (where I live), Jacksonville FL, and Tennessee (recent road trip). I'm not sure if anyone else has noticed this. I expected that this is a new system we would have data that was at least current in 2010. I'm a little disappointed. The system does work well overall, although the Nav Traffic usefulness is mediocre. That's a problem with the provider not Ford. Data is often old or not relevant. I've seen new alerts that weren't accurate or seemed worse that depicted on the alert. I do wish we had a scroll wheel/knob as it's hard to use touch to move around the screen. But there are other very useful items such as being able to have context sensitive menu choices such as magnification values. It's a good deal at 795 MSRP compared to some other companies that bundle everything into a $2K nav package.
	Coming from a G35 i'm used to near-instantaneous throttle response. The G had paddle shifters but never used them due to awesome auto. Obviously don't have that with the Edge Sport but I do find that I use the paddles occasionally when doing highway maneuvers such as merge/on-ramps. I find you need to work the Edge tranny a little more to prevent quick upshifts that rob that torque. They do work nicely once you get used to the concept. Wouldn't really use them for stop/go traffic.
	Welcome and congrats! You are now part of the majority/minority of Plat White Sport owners (clearly the best color choice for this car, but I'm biased). Agree on the tint comment... it really unifies the look. Enjoy your new ride!
	  Is there anyone NOT having MFT issues?GatorCat replied to Tina's topic in Audio, Backup, Navigation & SYNC Had my 2011 Sport for about a month and only the same basic issues many have. BT streaming audio won't work with iPhone. Occasional minor bugs but so far my MFT is working as advertised. Hoping these fixes are resolved soon for everyone as this is a super-frustrating problem. I would put myself in the "works" category.
	  Front License plate holder REMOVALGatorCat replied to Edgieguy's topic in Accessories & Modifications Had the same problem with mine. Dealer accidentally ordered the front plate bracket when placing order for my car, as it comes installed from factory. I was pissed too when I went to pickup the car. Dealer was like, I won't order a new grill since that's 500 bucks, but I'll order a whole Sport model and swap out the grill when it gets here in 2-3 months. If I have any paint chips or bug damage he wouldn't swap out the grill. So I asked them to remove the bracket and see what they can do. They found a couple of plugs that sit very tight in the large holes. It's not ideal, but I can live with it (plus I'm leasing so in 36 months it's gone). These pictures accentuate the caps since I captured the light hitting them. In normal conditions you really can't tell much. Doesn't detract from overall look as much as the dumb plate bracket. If I were keeping the car for 10 years I might have gone the swap-a-grill route. Someone else on the board here had the dealer order a new grill... YMMV.
	Have you tried un-pairing and re-pairing the phone first? Couldn't hurt. Hope it's just a small issue...
	Dealers have them. I had one installed against my will when I ordered my car. Had them remove it. Don't know about price. This is the one that goes right over the grill at the edge of the hood... looks like a handlebar mustache. Had to have it removed.
	  Does anyone have a 2011 Edge that works?GatorCat replied to juscruzn's topic in Audio, Backup, Navigation & SYNC I have a 2011 Sport and successfully paired iPhone 4. I'm just at 300 miles, and a week into it. The majority of MFT items work fine. I am having some issues with the BT music/audio, but as we all know BT audio stack problems are often on both sides of the hardware, and Apple has notoriously had problems with BT audio on a variety of sources. Does the MFT occasionally do something weird? Yes. But it sounds like upcoming software updates will begin to address those issues. Keep hope alive!
	  Report your new 2011 Ford Edge or Lincoln MKX delivery here!GatorCat replied to LIVIO's topic in 2011 Edge & MKX Sweet! Hope yours is built right! Enjoy the new car smell. I also had a G35 and turned my lease in on Monday. Was a little bittersweet... I really loved that car! This is a completely different ride.
	Hmmm... if you had a fair bit of room then maybe you weren't truly at the last notch of the post. Because when I did mine I was literally rubbing the roof trying to get it out. Of course the seats recline somewhat but mine were only reclined a little, so maybe your were more reclined? It really only took me about 5 minutes. So weird that both of you had problems. I'm no mechanical genius, but I did have to apply a fair bit of force, but I figured you can't really break off a steel headrest post. The center headrest is smack dab in the way and I'm annoyed you can't lower it unless you bring down the entire armrest at which point you can't easily access the seat belts (I have carseats in the back). Nothing's perfect...
	Well that's crazy, but if you didn't actually sign the contract then your deposit is refundable. Hopefully you put the deposit on your credit card, and if so you can dispute the charge with the credit card company. Don't let them push you around. That said, probably faster to have the glass replaced than to find an exact copy of your new Sport somewhere. Although, in principle I would be mad at them for trying to screw around with your deposit. Good luck!
	  2011 Edge Ltd + iPhone4 USB Audio "pops"GatorCat replied to FirstReflect's topic in Audio, Backup, Navigation & SYNC Just chiming in here... I have iPhone 4 running 4.1 (32GB) and 2011 Edge Sport. I don't have any audio problems with USB connection, although I can't get streaming to work via BT audio. However, I was playing with the video option through regular USB port (which only does audio portion of movie since the video needs to be hooked up separately). Anyway, the audio portion did have tons of drops and pops. Got me to thinking there may be some correlation to type of file (AAC 128/256, protected vs. unprotected, MP3, etc.). Hoping that the 4.2 update helps. There's definitely issues with iPhone connectivity but I think it varies by model and receiver. We'll see!
	I have the 2011 sport (should be same) and have successfully removed outboard headrests. The center headrest is NOT removable. You have to extend to highest setting first, then press both tabs on both posts and wiggle to extract. I did it with seats up (although it bumped up against the roof). Maybe that's the difference?
	  Is the Jukebox a myth on 2011 MyFord?GatorCat replied to DistortedEdge's topic in Audio, Backup, Navigation & SYNC As far as I can tell you can't rip any other media to an internal HD. There is some internal memory since you can replay Sat radio, but you can't rip from one media to an internal drive. Best recommendation is to dump your media either to a USB stick or some other device and use that. USB sticks are rock cheap and you can get 16GB and keep it in your car with all your media. I think the internal HD is going to be a dinosaur after a couple of years anyway as we move to keep our music in the "clouds" anyway.
	Just got my 2011 Sport AWD. First domestic after owning several German/Japanese cars, coming off a G35. So far so good. The AWD works great. You can watch power distribution and under spirited acceleration from standstill in dry weather it distributes power to both rear and front for a nice linear feel. I'm a RWD guy and was a little nervous about going FWD. The AWD makes it feel better. I think you'll be satisfied. I probably won't see much snow down here, although we will be in the Tenn mountains over Christmas so we'll see! Good luck!
	  Driver Entry SettingsGatorCat replied to Edgieguy's topic in Alarms, Keyless Entry, Locks & Remote Start Naw, that would be nice. Sensors only on front doors. Gotta at least touch the inside of either front door to unlock the doors. Works pretty well otherwise.
