ravishingrocket
    2
Everything posted by ravishingrocket
  1. Could i just swap in an aftermarket touch stereo instead of the MFT screen?
  2. Anyone know where I could get the necessary wiring harness to upgrade to the MFT screen?
  3. What options do I have for a grill cover besides buying the OEM quarter trim? Aluminum mesh?
  4. Will a 10" sub fit into the stock box without modifying the opening?
  5. Read I should get a signal processor. Now what about the amp situation?
  6. I just picked up a stock sub enclosure. What do I need to install this? Does this have a built in amp or was the amp a seperate peice in the sony system? Or does it even need an amp?
  7. In my wife's 4runner, the cupholders are rather large with an adjustment bar to accomodate smaller sized bottles/cups. I like
  8. Is it just me or does the center console cupholders seem a bit useless? Powerade bottles don't fit in either holder, vitamin water doesn't fit all the way in the smaller holder, while the same holds true in the front holder if the rubber peice is installed. Its a bit annoying having to remove and replace that rubber peice depending on what bottle/cup you put in there.
  9. Any aftermarket solutions to the OEM kit? I would want to add the additional lighting to match all the factory locations, but also want the colors to match. Anything that will have the choice of colors to cycle thru?
  10. The ambient lighting installation instructions say to drill a 17.5mm hole behind the gear shift and 1 inch in front of the armrest for the switch. Anyone have a pic of this?
  11. Noticed some brackets and bolts exposed. Is there suppose to be some plastic covers there?
  12. Know the dimensions of your amp? How much extra room is in there?
  13. I assume that amp fits there with the OEM panels in place?
  14. Did you install a sub or just spliced into the speaker wire?
  15. Are there any OEM or OEM like carpet mats for the rear seats in the one peice design? Im only seeing the one peice in the all weather mats. Thanks
  16. I see pics of the factory setup showing lights in the door handles and the door storage area, but websites selling the OEM kit say nothing about either. Has anyone bought the OEM kit and can tell me if it has these lights? Also, where is the factory switch/button located that controls the ambient lighting?
  17. I just got my car yesterday. Finally! Only took 10 weeks... I haven't had any time to look things over, but I might get the Metra kit when it comes out so I can install an aftermarket stereo with outputs for an amp
  18. Anyone know if the 2010 edge stereo harness will work on the 2013? Or if one exsist for the 2013?
  19. Shipping spring 2013....meaning Metra is shipping to retailers for sale?
  20. Looks like that would work, but still looks like you have to cut the factory bezel. Where would you cut tho? Above or below the CD slot? What about the Airbag indicator?
  21. Well, I had called my salesman only a few days after placing my order cuz I wanted to add some options, but I was told it was too late. I dont understand why it was too late cuz it took 6 weeks just to get a VIN. I was finally able to view my window sticker a few days ago and it has a date of 04/19/13. I didn't know I could swap out my factory screen/stereo for an aftermarker one. I have a 2013
