Hollywood1
    3
Everything posted by Hollywood1
  1. Well...to each his own. I installed car audio professionally for 6 years. As far as mass-produced, I definitely have my preferences, Morel components for midbass drivers, JL Audio for subs, AudioControl for factory integration. The HD series amps from JL are simply amazing. They consistently make more power than advertised and the crossovers are super accurate (in the HDs). In my previous 2008 MKX I removed the factory sub and put in a custom fiberglass box with a JL 8W3V3 (box was .85 cu ft), Morel Elate 6.5 components front and 5.25 rear and integrated with an AudioControl LC7i. That system was amazing, crystal clear, tight mid bass and thunderous sub bass, I miss it. Do you have any experience with fiberglass? You could really open up your custom solutions with some glass work. As far as running a midbass driver in the rear, I don't think those frequencies would travel far enough from the rear without getting sucked up by seats, carpet and reflections to be very audible. Good luck on whichever route you decide to take, let me know if I can help with anything.
  2. I think your design looks nice. You should be able to sand/shape the corners for a smooth look. If you remove the stock sub, but leave the grill in place (using black cloth to block the view into the space) you could mount your amp in that space and maintain ventilation. I haven't used those subs before, but I can recommend the JL Audio HD series amps, they run very cool and are extremely compact. I'm not sure if you can make space for a 1 cu ft enclosure, but with the JL Audio 8W7, you would only need one. This sub absolutely pounds!! I have personally replaced a pair of 10W0 subs each getting 200 watts with the 8W7, and using the same amp the 8 inch was producing noticeably more SPL and bass.
  3. That's weird that their application for the Edge is so loud. That makes me feel better about ordering it through Amazon so that I can return it easily if I have the same opinion. Maybe it's because if the removal of the Ford intake resonance silencer. I personally dont believe in an intake for looks, so if its too loud or doesn't give a perceivable gain in power it will be going back. I happen to live in a dusty area which is the reason I always go with a reuse able air filter. I am actually more excited for the exhaust, as I love the sound of this motor in the Mustang. The DRLs will also be pretty cool. So..... nobody has or knows anyone that funds the Steeda sway bar huh?
  4. Do you have personal experience with this intake? I also have an AFE dry-s drop in filter that I can use. As for ceramic pads, I have had experience with the Centric ceramic pads and I have run Hawk pads on my S4. I agree that ceramics can eat rotors, but only with track-level use, which the Edge will never see. I like the low dust of ceramics, and they were included in the kit I bought from Amazon, so I'll stick with them. Back on point, does anyone run the Steeda rear bar?
  5. So I just took delivery of my 2011 Edge Sport and I want to change a few things and mod a little. I have ordered the Magnaflow exhaust, K&N intake, H&R springs, bright lights LED DRLs, and a full PowerStop slotted/drilled rotor and pad upgrade. I want to try out out the Steeda sway bar, but it is only .1inch (3mm) larger than stock. Is anyone here running one that can offer an opinion on the change in handling? Thanks in advance.
  6. Due to where you live I would say that the rust issues are normal, and a brake pad separating from the backing is not normal, but not exactly rare either. Brakes are one place where you should not go cheap. As for the dealers response, I would unfortunately say they are right. Brake pads and rotors are a wearable item, and if the caliper has not malfunctioned, it is hard to hold Ford responsible for a defective brake pad. They are advising you to replace both rear rotors because they are sold in pairs, as are brake pads. As for replacing the fronts also, they may be trying to make some money off you, but without you taking the car to another dealer or an independent, it is hard to tel. I would doubt that the dealer would even let you take the car back without the repair due to liability. I hate to say it, but I would either pony up and pay for a full brake service or have them tow the car to your house. You can get a full PowerStop brake kit including slotted rotors and ceramic pads for the front and rear from Amazon for $400 with free shipping and the job can be completed in your garage with simple hand tools. Good luck
