my 2012 edge
Everything posted by my 2012 edge
  1. ok i think thats what i should try
  2. if i rebuild mine do i have to reprogram it
  3. im not sure part no. i was told a used one has to be repogrammed. is that true
  4. i need to find someone that can rebuild mine. otherwise i have to reprogram it thru ford
  5. i also replaced the battery which made no difference
  6. i havent fixed it. i brought it to ford they said its the abs module which is on backorder. still driving it just annoying lights and chimes. very fustrating
  7. on my 2012 ford edge all warning lights came on brought it to ford they said code u3000. which is a abs module which is on backorder with no eta. can i rebuild the factory one orvis there a aftermarket available
  8. my 2012 edge
    code p193c
    my service advance trac light came on my 2012 ford edge. it turned off by itself. i checked for codes and got p193c anyone familiar with this. i dont see any issues driving
  9. i did on my 2012. it was the brake booster i think it was a recall
  10. Sometimes it chimes after I take the key out. I put the key back in and start car and turn it off and it goes away
  11. I have this code on my 2012 ford edge any ideas thanks
  12. Thanks I'll try and figure it out
  13. I have a 2012 edge just replaced battery two weeks ago. Now I have this code I cleared it and it came back any ideas
  14. When I pressed on the brake it would go straight to the floor
  15. I had a very soft pedal. I changed master cylinder and bleed brakes it's better but not good. My son come over with scanner a day code COO2O-13 came on any one familiar with this
  16. Battery died thus morning. My mechanic said its the alternator
  17. I don't have any aftermarket things except remote start
  18. Yes it was acting up the battery died it was 3 years old. Hiw do you rest the bms? Is locking the vehicle overnight enough?
  19. I get this warning when I start my 2012 edge. It goes away after I start driving. I put a new serpentine belt on and a brand new battery. Auto zone says the alt. Is good. When I drive the car I use the torque app to check batt voltage and it is usually 14 volts. Any idea why I keep getting this warning thanks
