my 2012 edge
Everything posted by my 2012 edge
  1. Sorry for the confusion. I changed the pvc valve also at the same time as the front valve cover.. after I did that the smell was there one more time.then I cleaned out the tube that connects to the throttle body and it never happened again. Pretty simple job changing valve cover
  2. Since I changed the valve cover the smell went away
  3. I mite replace purge valve since it cheap
  4. Th ac drain is clean and I just drove it very aggressively and no smell
  5. I have changed the cabin filter.it happens during regular driving not acceleration.dosent happen everything i use climate control where the evapoter drain
  6. It has 55k smell seems to be coming from the vents uts better but still there at times si ce u changed the front valve cover. I think it only comes on when you turn the heat or air on
  7. It has 55k smell seems to be coming from the vents
  8. No problem starting and I checked the purge valve and its working
  9. Sorry gasoline. Never rear-ended and its awd
  10. I have a 2012 edge with the 3.5l engine. Sporadically I get a gas smell in the cabin. I already changed the pvc valve and front valve cover because I was getting oil in the intake tube. Ant ideas what could be causing this thanks
  11. It's not screaming just whining it's been warm the last two days and no noise just when it's cold
  12. I have a 2012 edge sel with a v6 with 29k miles when I first start the car on a cold morning I hear a whining noise that goes away when warm. Any ideas if it's the tensioner o r belt any hints to Changi g it thanks
  13. Do you know where you can a sticker from
  14. I have a 2012 edge and the front emblem is just chrome.Was the blue part a sticker? There is no sticky residue on the emblem I only have 18 thousand miles on the car
  15. My 2012 edge does that if the rear tailgate isn't closed all the way
  16. My can wires were marked wrong from the factory call tech support and ask him if that's why you can't program it that was my problem I didn't splice any wires on mine
  17. I have that remote and it works great call the tech support there very helpful
  18. I just connected the t harness like the video shows then I used those two plastic clips for the can h and can l wires then programmed it like the video shows did you get two plastic clamps I think they were pink
  19. I did this in my 2012 edge it took maybe a half hour it works great call his tech support he was very helpful you don't have to splice any wires he gave you plastic clamps for the wires
  20. I got husky mud flaps on my 2012 and love them
  21. Why not try to refinance your existing car loan to a lower interest rate
  22. Ya how much for one rim shipped to 11776 new york thanks
  23. how about certified used it comes with a extended warranty
