my 2012 edge
Everything posted by my 2012 edge
  1. on my 2012 ford edge all warning lights came on brought it to ford they said code u3000. which is a abs module which is on backorder with no eta. can i rebuild the factory one orvis there a aftermarket available
  2. my 2012 edge
    code p193c
    my service advance trac light came on my 2012 ford edge. it turned off by itself. i checked for codes and got p193c anyone familiar with this. i dont see any issues driving
  3. i did on my 2012. it was the brake booster i think it was a recall
  4. Sometimes it chimes after I take the key out. I put the key back in and start car and turn it off and it goes away
  5. I have this code on my 2012 ford edge any ideas thanks
  6. Thanks I'll try and figure it out
  7. I have a 2012 edge just replaced battery two weeks ago. Now I have this code I cleared it and it came back any ideas
  8. When I pressed on the brake it would go straight to the floor
  9. I had a very soft pedal. I changed master cylinder and bleed brakes it's better but not good. My son come over with scanner a day code COO2O-13 came on any one familiar with this
  10. Battery died thus morning. My mechanic said its the alternator
  11. I don't have any aftermarket things except remote start
  12. Yes it was acting up the battery died it was 3 years old. Hiw do you rest the bms? Is locking the vehicle overnight enough?
  13. I get this warning when I start my 2012 edge. It goes away after I start driving. I put a new serpentine belt on and a brand new battery. Auto zone says the alt. Is good. When I drive the car I use the torque app to check batt voltage and it is usually 14 volts. Any idea why I keep getting this warning thanks
  14. Sorry for the confusion. I changed the pvc valve also at the same time as the front valve cover.. after I did that the smell was there one more time.then I cleaned out the tube that connects to the throttle body and it never happened again. Pretty simple job changing valve cover
  15. Since I changed the valve cover the smell went away
  16. I mite replace purge valve since it cheap
  17. Th ac drain is clean and I just drove it very aggressively and no smell
  18. I have changed the cabin filter.it happens during regular driving not acceleration.dosent happen everything i use climate control where the evapoter drain
  19. It has 55k smell seems to be coming from the vents uts better but still there at times si ce u changed the front valve cover. I think it only comes on when you turn the heat or air on
